I have a pen drive of 2GB of Jetflash.After using it a ini file named autorun appears in the Hard drives of computer and in my pen drive.It was coming again and again after deleting.PLz Help me
is there and U3 software installed on the device? could you post the contence of th INI file for us to see?
it sounds like you have a program on the pendrive autorunnig when you connect the pendrive this could be some software that can with the drive from the manufacture or something more nasty like a trojan. if you really want to fix it copy everything you want off the drive then format it, this is the quick dirty way of fixing the problem but if you have a U3 style smart disk the autorun software will stay intact.
I've got a problem with my TRANS-IT USB 2.0 FLASH DRIVE 8GB LOCK IT. Last time when I was trying to...
(More)
I've got a problem with my TRANS-IT USB 2.0 FLASH DRIVE 8GB LOCK IT. Last time when I was trying to use it my windows XP has formatted and deleted all info with LOCK IT and now how can I get a security program because when I'm downloading it from TDK main site and trying to turn it on it shows me that my pendrive is broken and it's turning down my TDK 8 GB is normally working withought it but I want back that 500MB that was on secured area
I would like a replacement roller for the scanner, as the scanner will not feed the pages through...
(More)
I would like a replacement roller for the scanner, as the scanner will not feed the pages through seperatly. I think the problem is with the scanner roller. Kind regards adele.armstrong@doctorcall.co.uk
