Question about GE Refrigerators
I have a GE Profile French door refrigerator. the refig lights are dim. Open the freezer and everything lights up.
SOURCE: samsung refrigerator
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Posted on Apr 16, 2008
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
Maytag317
  • 1136 Answers
SOURCE: The door handle on the freezer of my GE Profile
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Posted on Jul 11, 2009
sawdust46694
  • 398 Answers
SOURCE: GE Profile Arctica freezer door not sealing properly.
Loosen the hinges on top of the door left side, . lift or lower the door till it is level with the top of the unit. now do the other door. now look at the line between both doors, and compare the gap at the top and bottom . adjust once more time if needed. clean the metal and the magnet with windex then put weson oil on a clean towel and wipe all the way around each door.. hope this was helpfull to you.... Sawdust46
Posted on Aug 11, 2009
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
How to get the light to come on in the freezer side by side ge profile artica?
Open the door. The door switch should pop out, the light should come on. If the bulb is burnt out, that would hinder the process. If the bulb is good, I would start with checking voltage at the receptacle and work backwards thru the door switch until I found where the power was lost.
Sep 01, 2016 | GE Profile PFS22 33" Artica French Door...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
ICE MAKER NOT WORKING ON GE PFS22SISBSS
Lets try this first. Unplug and then wait 10 minutes and then replug. That should reset the memory for the motherboard. If that does not work contact me asap, Sea Breeze
Mar 13, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
My GE Fridge is not getting cold
if the freezer is still o.k. then replace the control board located in the lower rear of the unit
Dec 24, 2009 | General Electric Profile PFSF5PJX Bottom...
Latch Hooks Not Working
This is a VERY common problem, and the fix can sometimes involve replacing the door.
The following site should have the latch/gasket assembly: http://www.repairclinic.com
AFAIK, the top latch can only be replaced with the entire door gasket assembly, but it's not too difficult to do.
A google search on 'GE refrigerator latch' will find you thousands of other (former) GE customers who have had this problem.
Oct 23, 2009 | Refrigerators
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Not cooling at all
refridgerator not cooling making clicking noise from back
May 03, 2009 | GE Profile Stainless Bottom-Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
