Question about Nextbook Tablets & eReaders
My nextbook nxa8q116r. Touchscreen is unresponsive. How do i fix it please and thankyou
Nextbook 10.1 touchscreen tablet. How do I determine required polarity of replacement power adapter if original adapter is missing?
unless you have a very way out machine all power adapter charges are wired the same way
all you need is the correct fitting to go into your machine
Nov 02, 2015 | Nextbook Tablets & eReaders
How do i calibrate my nextbook tablet
You can adjust the touchscreen calibration by going to Settings-->Touchscreen calibration on your Nextbook.
Jun 20, 2015 | Nextbook Tablets & eReaders
The charger port broke off in the tablet of Nextbook 8. Is there a way to remove/fix this?
To fix you must take apart the device. I suggest that you search for "How to repair XXXXXX on Nextbook 3"
If the port is not solder, you should be able to fix it. Best of luck.
Jan 02, 2015 | Nextbook Tablets & eReaders
How do i switch the camera around?
Per the following review, this device has no rear-facing camera, but only a front-facing camera, and is only designed for selfies and video calls...
Jul 15, 2014 | Nextbook Tablets & eReaders
Broken, Unresponsive, Cracked Screen
If the light crystal is broken then you would either have to buy a new one or get it fixed for $500-800
If the screen is just cracked you can her it replaced at a local store I believed for about $100 at most hope I helped!!!
Nov 21, 2013 | Nextbook Premium 8 Se Android
On nextbook 8se
Aug 15, 2013 | Nextbook Premium 8 Se Android
I can't unlock my nextbook tablet
If you're willing to reset to factory defaults, then there is a way to fix this. However, the reset will delete all data and any apps installed that didn't come with the Nextbook Tablet originally.
Dec 18, 2012 | Nextbook Tablets & eReaders
Tablets & eReaders Logo
29 people viewed this question
Top Nextbook Tablets & eReaders Experts
Nhat Nguyen
Andrew Taylor
Andrew Taylor
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
