Question about Pioneer VSX-D510 Receiver
Pioneer vsx d510 "Power off error"
My stero displays "power off" and after about 2 seconds does just that. I have unplugged ALL wires...placed in a different outlet...and it still does it.
  • 10,594 Answers
Your stereo player got problem in output section so protection circuit activated and shut down the system for its safety.
Please take the unit to qualified tech for fix as it is not DIY thing.
Thanks.
Posted on Jul 24, 2009
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
SNES no power (light on for 1/2 second) Fuse good
Well I think that the fuse is blown on the system. 1.5amp pico fuse.
Oct 16, 2009 | Nintendo Super NES Console
Just bought HPJ4550 and will not turn on during initial setup. Appears to be power to the cord as the green light is on on the coverter.
Ok. The most obvious things first. Unplug the power from the printer itself and plug it back in. Next, press the power button just 1 time and wait 10-15 seconds. If you do not see any lights or display, try a different outlet. If you still cannot get a response from the printer even after trying a different outlet, the printer or power cord is defective.
Aug 22, 2009 | Office Equipment & Supplies
Will not print fax's
1. Unplug the fax machine from the power outlet.
2. Press and hold the "Stop/Exit" key, then plug the power cord back into the power outlet.
3. Continue to hold the "Stop/Exit" key for 5 seconds. The display will return to date and time.
4. If the display does not return to date and time, please repeat the process to make sure the procedure was completed correctly.
May 20, 2009 | Brother IntelliFAX 5750e Laser Fax
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Stero not coming on
What kind of car do you have? This can make the difference. Many cars with small engines (eg. Geo Metro) simply do not generate enough power to operate the radio. Other times the car can generate enough power to support the radio, but when you plug something into the cigarette lighter/power outlet the radio shuts off because the car isn't powerful enough to handle both. The first thing you need to do is to make sure that the car's electrical output is sufficient to operate the radio, after that it would be a good idea to make sure that all of the wires are connected properly.
Oct 29, 2008 | Pioneer KEH-P4020 Cassette Player
Black Spots
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Sep 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
Pioneer VSX-D510 Receiver Logo
306 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
