Question about Whirlpool Dryers
I have a Whirlpool Dryer Model #LER5636PTO that isn't getting hot and it is staying stuck on the cool cycle only. Could someone help me with this? Could it be the heating element?
    Master:
  • 923 Answers
SOURCE: whirlpool elec dryer
check your lint filter, take it to the sink and see if it holds water. it may be clogged from using fabric softner in youe washer.
Posted on Nov 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool electric dryer, Model LEC6646ANO. On
Make sure the internal and external exhaust vents are not blocked with lint.
Will it complete a 45 minute time dry and dry the laundry?
Posted on Mar 09, 2009
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
SOURCE: Whirlpool dryer gets too hot and won't cool during
check to see if your heater element has been grounded (broke and touching housing) and if not, replace your timer
Posted on Oct 29, 2009
  • 867 Answers
SOURCE: whirlpool dryer model wed5600sq0 won't cool down
If it does not shut off during the cool down part of the cycle then the issue is with the electronics
Posted on Mar 11, 2012
Electric Whirlpool dryer won't cool down during drying cycle and even gets hot during air fluff cycle. Replaced thermal fuse and is still the same.
There are two thermostats on my whirlpool model number 857554115010.
Both should be replaced at the same time.
I found a good video on
http://www.espares.co.uk/advice/tumble-dryers
I bought the parts from them and it worked.
Sep 12, 2013 | Whirlpool Dryers
Whirlpool dryer model wed5600sq0 won't cool down
Mar 10, 2012 | Whirlpool Dryers
My whirlpool washer periodically gets stuck on rinse.. the water continues to run but its only about half full so it must be draining. My water bill was over $100 last month, please help.
check the lid switch, if it isn't working right the machine will not enter the spin cycle, also the timer may be going bad, it could stay stuck in between the rinse fill and rinse cycle
Jun 21, 2011 | Whirlpool Washing Machines
Whirlpool duet dryer, dryer gets to hot, even on delicate cycle, clothes to hot to touch
may be the heat sensor(around 10Kohm) or the heater relay on the control stuck in the on position.(new control)
Oct 29, 2010 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool LER4634J Electric Dryer that has stopped mid-cycle and will not restart. I know VERY LITTLE about dryers so please use plain language if you give suggestions about how to fix it. Thanks!
1. Does it have electric power? Is the breaker or fuse good? Is the power plug loose?
2. Is the door to the dryer ajar? Please open and close it a few times to check this.
If this doesn't help, you may need new or repaired parts. The timer motor that turns the dryer switch may have failed. The clutch that allows you to turn the select knob for the different dryer cycles may be slipping and have failed. The start button that begins the dryer cycle may have failed after a temporary power outage. The door switch may have failed. The particular switch in the dryer cycle setting you are using may have failed (Other cycles may still work). The dryer thermostat(s) may have failed (prevents too hot/ over-heating). Follow the wires from the "heat selection switch" to find thermostat(s) in the hot air duct. They "turn ON" when too cool and "turn OFF" when hot enough. Mechanical switch contacts can "melt together" and stay always ON. Or switches can get pitted and stay "always OFF" after enough ON/OFF cycles. If pitted contacts happen, you can see this on them. Sometimes a finger nail file (I do not recommend a metal one) can shine them up again. Solid state (electronic) switches have to be tested with a meter or something else to see failure. Please don't do work on electrical or any other problems while the dryer is plugged in or still hot. Good luck. Your mileage may vary. ;-)
Aug 03, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer not fully drying
You have a ventilation problem. Either internally in the dryer or more likely hose behind dryer is linked or there is an obstruction somewhere from dryer to end of line outside.
Nov 03, 2017 | Whirlpool LGN2000LWH Gas Dryer
Mar 09, 2009 | Whirlpool Dryers
Starts cycle and then stops
Jirina, first check to make sure that both the hot and cold water valves are turned on. If that's ok, check to make sure the lid switch is being actuated. Check those first...Catriver.
May 29, 2007 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
