Question about Dometic Heating & Cooling
I need a replacement AC unit compatible with my duo therm dometic 13500 BTU model 57915.751EQ. What unit do I need to order and will the wiring harness work
    Top Expert:
  • Dometic Master
  • 8,694 Answers
Make sure dip switches correct and use ac cable not phone cable
Posted on Sep 15, 2017
22yooper
  • 828 Answers
SOURCE: duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Posted on May 31, 2008
meBNme
  • 334 Answers
SOURCE: Duo-Therm AC bearing noise
Yes, it sounds like your bearings are bad. If it is cooling, then you know the compressor is working.
The only other thing really, would be the motor.
Posted on Oct 02, 2009
Testimonial: "Very Professional "
motor1258
  • 6674 Answers
SOURCE: I have a dometic duo therm roof ac unit that is
It is a closed system, (ends are soldered) that said, a heating and cooling guy may be able to install fill valves and re-charge for you, but make sure you get a quote ahead of time. How old is the unit? Not normal for them to need re-charge, and I've seen them work good for 15 years, if maintained properly. Has it been completely cleaned recently?
Posted on May 27, 2010
motor1258
  • 6674 Answers
SOURCE: my Dometic duo therm unit sounds like it runs when...
Condensor fan at rear of unit may have a faulty relay sticking.
SOURCE: Dometic Duo Therm, 15000 BTU: Thermostat
Our domrtic air and furance will not come on at all. No clicks when we try the theranstat Dometic told us to unplug the thermonstat but do not know where it is located. we have an anolog thermonstat . Also any other thing that might help me to troubleshoot, we live many miles from dealer.
Posted on Aug 05, 2010
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Fan runs but does not cool
Always take pictures first before you fix
anything, or take it apart. so you will know how to put things back
Aug 15, 2015 | Dometic New 13500 BTU Duo Therm Brisk RV...
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
I have a Duo-Therm 57915 (13500 BTU) that frosts up the bottom 1/4 of the coil and shows signs of a freon leak on the copper tubing (oily substance). I assume I have a freon leak. It a 2006 unit. Is it...
Buy a new one. Your repair will cost approx 2/3rd (or more) the price of your new unit. Your old unit has no warranty left while your new unit will have a warranty. :-)
May 03, 2010 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Rooftop a/c not cooling as well as it used to.
How old is this unit? In the Duo-Therm Brisk Air Models, they were notorious for a small leak in the capillary tube that runs into the evaporator part of the AC. There are two small tubes that are run together, take the top off of the evaporator coil and pull the lines apart gently. Look for noticeable signs of leaking in the area. If the lines have been looking or look like they have rubbed together for an extended period of time, you need to have someone replace the lines or buy a new air conditioner. I would price both before committing to either one. Hope this helps.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
