Question about Watches
Model UL1188 C311 new battery but hands wont move digital is part works
4 Suggested Answers
  • 5 Answers
SOURCE: Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Posted on Feb 19, 2009
  • 2501 Answers
SOURCE: the digital on my watch
Send it back and ask for a repair under warranty.
Don't try anything yourself as it may invalidate the warranty.
Posted on Apr 20, 2011
small6363
  • 18413 Answers
SOURCE: changed battery on Accurist BJ3547 as hands stopped though digital signal was still OK. New battery installed, digital signal still OK but hands still don't move . A video said a reset req'd, How?
  1. The "AC "or "All Clear Circuit" button if the watch has one will be found on the back of the movement. It will usually be a small silver or gold dot marked "AC" or reset. In some cases it will be a small hole or plunger you depress with a pin punch.
  2. Clear watch memory. Look for and find the small gold or silver dot on the back of the Seiko watches movement. It will be marked "AC" if it exists. Use the metal tweezers and touch the "AC" button with one prong and the battery with the other. In some cases you just push in the plunger on the "AC" button. In the case of a plunger or hole press it with a pin punch.
Posted on Aug 15, 2016
Have new battery lite works and digital working i tunn hands like to wind it and they move
The hands are sliding at the base. set at 3:00 and a drop of crazy glue should move them when set.
good luck
Apr 22, 2017 | Watches
Hands wont move but the digital part works
That watch might take two batteries when it's open there should be a big battery which is a lithium but under it will be a silver oxide batter that needs to be replaced if there is not then the analog has to be lubricated and spun out the worst case senerial is u will have to replace the movement remember all was change ur batteries asap when the go dead. Digital batteries always last longer than the analog batts do
Apr 22, 2017 | The Watches
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Jan 09, 2010 | Timex Ironman Triathlon 50 Lap Digital...
I have a Pulsar Analogue & Digital Type Series PP4 model PP4005. I am having trouble setting the analog time. When I rotate the crown, the minute hand and hour hand rotate, but when I set the correct...
It's broken. Mine is doing the same thing. Others online have experienced the same defect. I bought mine from woot.com in July and just gave it to my son for Christmas. Check the Seiko website and send it in for repair. It has a 3 yr warranty.
Nov 23, 2009 | Watches
The hour & minute hands on my pulsar nx14-x001 do not move. the second hand quivers, but also does not move. the digital time and other functions are okay. HELP!
Without knowing the model of the watch i would say you need a new battery. It is typical for this style of watch to have two batteries or one lithium battery. In either case the analog movement will drain faster than the digital portion of the watch and will stop working first.
Sep 21, 2009 | Pulsar Watches
Hands don't move - digital stuff works
the hands could be silghtly bent or to tight for them to move if not change the battery
Jun 02, 2009 | Citizen Watches
Watches Logo
20 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
