Question about Exercise & Fitness
Roadmaster treadmill 9562wm front roller - Exercise & Fitness
3 Suggested Answers
SOURCE: Please help..Need manual for 1993 Roadmaster treadmill.
Got one...also an excellent condition model 9562-WM treadmill for sale too. Email: mike@murphway.net
Posted on Oct 21, 2009
SOURCE: Front roller spare part for Vitesse Treadmil
I'm looking for a manual for the same treadmill can you help.
Posted on Oct 11, 2011
I need to replace the motor belt but i can't remove the front roller of my H140t Healthrider treadmill
There is one screw in the front roller
  1. Loosen the rear roller
  2. Remove drive belt
  3. Remove the 1 screw in front roller
  4. Pull roller out
Jan 01, 2014 | FreeMotion HealthRider "Club" Series H140t...
Belt off center on front roller
see the video and proceed according. God bless you
Jul 19, 2013 | Nordic Track NordicTrack A2750 PRO...
How to change belt
it's a big job, the front cover protecting the motor unit has to be removed, the rear roller has to be loosened inwards by using the large allen key to release the tension. The front roller has to be loosened and lifted out of the treadmill (it may need cleaned to take away any rust)
The rear roller can be lifted out and then the bed (running deck) needs unscrewed (allen keys) this should slide out. The new running belt should be put in place in the treadmill, place the front roller in place, the bed and the rear roller, fasten each of them up and adjust the rear roller so that the belt runs straight and it tight enough that when walking on it, you can't stop the belt.
Jan 17, 2012 | Life Fitness 9500HR Next Generation...
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
The treadmill is loose. How can this be fixed?
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud, then find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability.
If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt Tighten the bolt and test. If the problem is not corrected, repeat steps above and retest.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. Follow this procedure:
First remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Rear Roller Adjustment Bolts
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley and front roller must be replaced.
Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud. Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. then remove front roller and replace with new reverse procedure mentioned above
May 16, 2010 | Proform Sport 1000 Folding Treadmill...
Treadmill front roller has a rubber sleever that keep moving
That front roller's rubber sleeve by all rights should not be moving any which way. This mean the roller will have to be replaced call iconfitness @1-888-999-3756 and order a new up-graded front roller .
May 07, 2010 | RTO Image 15.0R Treadmill Walking Belt
Check Workout warehouse. Should be able to search them online.
Jun 03, 2009 | Proform 560hr Treadmill Walking Belt
Pulley slipping on front roller
Since the drive pulley is slipping on the roller itself, then the front roller will need to be replaced.
May 12, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
