Form C NO IS 364881 Dimakatso Matekane ? - Computers & Internet
I recently bought a samsung side by side refridgerator i accidentally scratch my handles, and are deep scratches as i can see the white material beneath the metallic coding.
Hello Dimakatso;
My Name is Peter. I am a retired field service refrigeration technician.
I assume you wish to remove the handles to replace them.
These handles are usually attached to the doors in one of two ways:
1.) There are two 3/32" Hex key screws, one at the top and one at bottom of each handle. Unscrew ( Back off) the screw until the Handle comes off. It is not necessary to completely remove the screw.
2.) There two brackets mounted on each refrigerator door. One at the top & one at the top and one bottom of each handle. There are two screws on the handle, one at the top and one at the bottom. These screw fit into a oversize hole on the bracket. There is a slot below the oversize hole that you push the screws on the back of the handle down into. So, to remove the handle pull up on the handle. You will need some muscle to pull the handle up.
Over time handles with the mounting bracket on the door become loose. You have to remove the handle (pull up) and tighten the bracket mounting screws on the door. Put the handle back on and push down to lock.
Oct 27, 2014 | Refrigerators
Is it mandatory to provide form 56b with form 56a?
Can you be a bit more clear? In what kind of PC Laptop?
Dec 24, 2012 | Toshiba Satellite PSPA0U01S006 Notebook
The form at http://www.thecondoexperts.info/form/basic.htm is not working. That form is on my landing web page at www.thecondoexperts.info. Can someone tell me how to correct the form in order to make...
For starters, your form named basic.htm has an incorrect function:
FORM
ID="frmMain" ACTION="http://www.thecondoexperts.info" METHOD=post>
should be
FORM ID="frmMain" ACTION="http://www.thecondoexperts.info/request.php" METHOD=post>
The request.php takes the form information when you press the Submit button, processes it and sends out and e-mail to your account and the customer. If there is an error in the form the request.php will send the customer to an error page instructing them to try again.
Oct 03, 2011 | Computers & Internet
Form feeding
try puting a piece of cardbord under the paper but tape it 3mm from the roller.
Jul 31, 2009 | AMT Datasouth ACCEL-6350 Matrix Printer
Hi all i want to launch a form when i click the data base file in MS access 2003 (the form is created inside the mdb file of access)
hi,
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Thanks.
Apr 01, 2009 | Microsoft Access 2003 for PC
Need to scan a form to be filled out to computer
If you scan a form onto a computer, it won't behave as a form by default. This is because the computer is just storing a picture of the form, and doesn't see it as a form.
To make a scanned form into an electronic version, you will need some software that lets you define the regions of the form that can be filled in by the user. the full version of Adobe Acrobat lets you do this, as do the less expensive programs CutePDF Professional or PDfill.
Basically, you scan your document into a pdf format and use the aforementioned software to define which regions on the form should have typable text, checkboxes, etc., then you re-save it as a fillable pdf.
This works well, I do this with all my rental applications, etc.
There is a little bit of learning required to do this, but if you spend some time with the program and its helpfile you'll be creating forms with the best of them!
Apr 22, 2008 | Office Equipment & Supplies
Restict closing the main form when some controls on the subform are empty
Hi there. I didn't notice this was so old until I had already worked on it for some time. Did you get this the way you want it? If not, I suggest either using a BeforeUpdate control to ensure the condition is met that the subform contain data, or validate the particular field(s) with isnull. Thanks for posting back if you still need help, or otherwise rating FixYa!
Oct 03, 2007 | Microsoft Office Standard for PC
News updat form
Menu -> Insert -> Form ->Form
Sep 13, 2007 | Macromedia Dreamweaver MX 2004
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
