Question about Baby Gear
Angelcare Ac1120 monitor battery charging symbol.
Just changed batteries and had a strange charging symbol appear. Can anyone help?
  • 11 Answers
SOURCE: strange symbol appeared, battery life now much shorter
Yes! That's definately your bluetooth indicator. Btw, there should be an icon glossary. try setting and tools/phone info/icon glossary. As far as the BT indicator check your bluetooth menu and disable it, assuming you have no BT peripherals as evidenced by your lack of understanding regarding the BT icon and effects of peripheral hardware on battery life.
You may also wish to do a little research on crop circles. But try not to get too weirded out.
Posted on Apr 21, 2009
SOURCE: moultrie camera locked up.
THROW IT IN THE TRASH! NO MORE PROBLEM.
Posted on May 04, 2009
  • 5 Answers
SOURCE: Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
Posted on Aug 20, 2009
  • 9 Answers
SOURCE: AngelCare Baby monitor and movement sensor AC401 mike problems.
Press Menu, then press Menu two more times until the icon on the far top left of the little display shows up, then you'll see the on/off option if you use the arrow keys. Use the arrow to select OFF and then press Select. Then press Exit.
Posted on Apr 16, 2010
SOURCE: Angelcare monitor Model #AC420-P no
Had exactly the same problem but this worked. Never even realised there was a button on the top of the unit!!! It looks like a little LED at the base of the hoop. Happy monitoring.
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT:
If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and
press and hold the MENU button ,the "out of range"indicator will flash and you will hear a
beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect.
The Tic light flashes.This normally happens within a few seconds and you will hear a bleep
to confirm it. If successful, the parents unit display will first show the channel of transmission (C1
to C8), which will be replaced by the room temperature and icons for all activated functions.
Note : The connecting process should be done within 30 seconds. If longer, the operation will be
ignored and you will have to start over.
• PAGING: If you want to locate the parents unit, press the top button of the nursery unit.
Posted on Aug 13, 2010
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Base not charging parent monitor
The rechargeable battery will need to be replaced.
Mar 20, 2012 | Angelcare Ac401 Deluxe Baby Movement Sound...
My Angelcare monitor was working fine for 1 month. Then I went to unplug it to move my crib to another room, went to plug it in and now it makes a weird constent beeping noise?? What is wrong with it the 2...
Without inspecting this item it is impossible to diagnose the problem. If the product is under 12 months old please return it to your retailer with proof of purchase.
Sep 10, 2011 | Angelcare Deluxe Movement Sensor & Sound...
Hello, my angelcare monitor is not charging, what can I do?
My Angelcare baby monitor stopped charging as well. I found that one of the terminals in the charging dock had broken the wire that connects it to the power cord plug. I re-soldered it back on and it works again!
Dec 24, 2010 | Angelcare Baby Sound Monitor White
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
Apr 08, 2010 | Angelcare Deluxe Movement Sensor & Sound...
Hi,sliding function not working,any help? andy
Try the following
Turn the ipod off and then on again.
If that does not work reset the ipod while it is connected to the power. You do this by pressing and holding the sleep/wake button and the home button at the same tme for at least 10 seconds, until either the apple logo or battery symbol appears. If the battery symbol appears, charge the ipod until it is fully charged.
Hope this helps.
Nov 26, 2009 | Apple iPod touch
Strange symbol on screen of my blackberry pearl
Generally rectangular box appears when you are in Roaming. After doing the Hardreset still if you are getting rectangular box in your handheld kindly walk into the nearest service center.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
I hope I was able to help you.
Thank you for using Fixya.
Nov 13, 2009 | RIM BlackBerry Pearl 8100
Baby Monitor False Alarm Problem
You can try adjusting the sensitivity on back of the nursery unit. But the most major thing I found was to ensure the sensor pad was on a firm surface. I used a large piece of cardboard from a flattened box. Angel Care recommends plywood or similar but the cardboard worked perfect for me. Put the sensor on top of the cardboard and then the mattress on top of that. The sensor should also be placed according to directions (under child approx center of mattress).
Jul 16, 2009 | Angelcare 2009 Movement Sensor Baby...
Baby Gear Logo
46 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
