Question about Minolta Office Equipment & Supplies
Minolta dialta di 181 CO500 service call
When machine switched on the display shows c0500 service call
  • Minolta Master
  • 6,696 Answers
Press the Trouble Reset Switch on the master Board for this fusing malfunction. Remove rear cover to gain access to control board, small little black switch, power must be on to do this be careful if the code come s back buy a new fuser unit, if you can find one. Quite old machine. DO NOT CONTINUE TO RESET the fuser can catch on fire that will ruin a perfectly good day.!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on May 06, 2017
jqsababa967
  • 145 Answers
SOURCE: Konica-Minolta DI-2510F Displays code C0500
Solution:
The C0500 code can be reset following the steps below:
1. Press the soft initialization on the right side of the control panel.{IT A SMAL HOLE THE SIZE OF PAPER CLIP IN DIAM-U CAN USE PAPER CLIP
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
GOOD LUCK
Posted on Dec 06, 2008
  • 15 Answers
SOURCE: error CO500
On the right side of cotrol panel there is small hole press it with clips .On the screen appear small dot press it then press 3 then apear screen chose from it troble reset .
Posted on Apr 09, 2009
firecontrol7
  • 6696 Answers
SOURCE: Minolta dialta di 181 error no c1440 machine not
Scanner exposure lamp out. Try opening thr front door to reset, if not new lamp
Posted on Jul 12, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: DIALTA DI 2510 CPIER DISPLAY CO500
C0500 is a fuser warm up failure code. The procedure to reset is simple. First look at the right side edge of your control panel. You need to locate the small hole in the panel which has a small switch behind it. It is located just to the right of the panel reset button, over the edge of the panel. You need a small paper clip or a tooth pick to insert into the hole to activate the switch. Next with the machine turned on and showing the code, insert something into the hole until the screen goes blank and begins to restart. You should see the initial screen come up. Keep watching the screen and at the far left side of the screen there will appear a small dot. As soon as the dot appears press the 3 key. You should now see a screen with several boxes. Touch the "Trouble Reset" box to reset the code. Then turn off/on the machine. Do this reset procedure ONLY 1 time for every 10 minutes. If the code comes back you can try again in 10 miutes. If the fuser is heating and the machine just can not "see" it then you can do further damage to the machine if you try to reset several times very quickly. If the machine warms up and makes copies you are all set. If the code comes back you have a failure in the fusing unit and will need it repaired.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 04, 2010
Co500 trouble code
C0500
Warm-up failure
- The surface temperature of the Fusing Roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle.
Jan 31, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Konica machine trouble service c0500 reset
On the right side of display located a display contrast key and a little hole.Under little hole is a reset switch,press the reset switch and wait to apeir * and press 3.
Jan 11, 2014 | Minolta DiALTA Di250 All-In-One Laser...
WheatlandServices
Nov 04, 2010 | Konica Minolta DiALTA Di200 Copier
Driver Windows 7 for Minolta dialta Di 181
NO! First Generation Digital machine from Minolta now konicaminolta, try this you will see,
Self Help Product Support Konica Minolta Business Solutions Inc
Oct 13, 2010 | Minolta DiALTA Di181 Printer
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Error CO500
Mar 30, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta Di181 C1300 Service call
my copier is minolta di 181 it shows c1300 .how can i repair this problme? thank you.
Dec 17, 2008 | Minolta DiALTA Di181 Printer
I have a Minolta Di351f. It indicates code CO500. This occurred after a power outage last night. What should I do to restore proper operation?Thanks.
Look on the right side of the control panel, just in front of the display contrast slider adjustment, and you will see a small hole. Using a paper clip or similar pointy instrument, press the pushbutton switch in that hole.
The machine will go into warmup mode. When you see a small dot centered on the left side of the touchscreen display, press "3" on the keypad. This will take you to the initial mode screen, where you will see "Trouble Reset" on the touchscreen. Press it.
If the C0500 code comes back in about 60 seconds, it means that you do indeed actually have a problem with the heater lamp not coming on, possibly a blown lamp or thermal fuse.
Dec 10, 2008 | Konica Minolta DiALTA Di200 Copier
41 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
