Replaced drain pump,began a load.Washed fine,wouldn't drain again.How do I reset it.I cut it off,turned back on,nothing happens.Also tried unplugging for seconds to minutes,plugged back in,nothing.
    Top Expert:
  • Washing Mach... Master
  • 50,084 Answers
Have a technician check the program board as there may no power to the pump
Posted on Apr 22, 2017
Not draining
You need the pump replaced.
Jun 15, 2009 | CDA CI532 Front Load Washer
Wash cycle not filling with water
Does the washed show an error?
Check all hoses in back. Remove them from washer and ensure water is coming from lines (drain into bucket).
Unplug washer for several minutes, then try again.
May 02, 2009 | LG WM2487H Front Load Washer
Front load washer won't drain
Possibly a blocked pump. Sounds about right if it has only happened after that item was washed.
Oct 30, 2008 | Washing Machines
The washer is not draining-It stops after agitating and will do nothing else
Hi, thanks for inquiring.The first culprit Id look at would be the lid switch.To replair .Remove two screws at bottom left and right of front panel.remove front panel.At top right, is lid switch . replace. Thanks,the appliance doc.
Oct 04, 2008 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
TROUBLESHOOTING
Ok here is what you do.
Unplug it for at least an hour. That means pul the plug out of the socket.
If it does not work I would advice to use the warranty of the machine. Call the store and let them replace it.
If you do not have waranty come back to me
Apr 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Apr 05, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
