Question about Sewing Machines
Embroidery on 780. Locked up and now I can't get it to embroider without knotting bobbin. Cleaned, oiled, rethreaded, broke 3 needles. Did this one day in class at dealer. What can I check?
  • Sewing Machines Master
  • 10,732 Answers
Only thing I can think of is to be sure to ALWAYS RAISE the presser foot when threading the top thread.
Posted on Apr 25, 2017
How do I fix my loose bottom tension?
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the machine from the beginning. Verify the path is correct. The standard tension setting is the midway point although you will most likely need to tweak this for your particular machine.
If you are still having problems, you may need to readjust the bobbin tension.
Understanding Thread Tension Threads
Feb 21, 2017 | Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
Why are no embroidery stitches showing up, the needle moves in and out of the fabric but no stitches stay
here are some suggestions, if the suggestions don't help then the
machine needs to be checked to see if there is a adjustment or
timing problem
1. try changing the needle
2. try rethreading the machine top and bobbin
3. make sure the bobbin is turned the right way in the bobbin
case
Jan 18, 2013 | Brother PE770 Computerized Sewing Machine
My top thread does not pick up the bobbin thread. I broke a needle in it the other day and replaced the needle and now having trouble with the bobbin thread. It is not turning? I am very new to embroidery....
Take off your throat plate and make sure that there is not a piece of your needle still in there, brush it out and oil your machine if it needs it. Now rethread.
Apr 21, 2011 | White Sewing White 4400 Computerized...
Bird nest when trying to sew. Under material by bobbin - tried changing needle, bobbin. Tension - no change to the problem from Auto for regular sewing to 2 for embroidery
i think you have something catch on the tension guides. Try to clean out anything you can see and pull a thread towards the needle. I have done this with a small knot to snare anything but be gentle. Also, rethread carefully.
Try cleaning the bobbin case too
Sep 12, 2010 | Janome Memory Craft 9500 Computerized...
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Thread Mess!
The symtoms you describe are typical to insufficient top tension.
First check the dension dial is on S for normal sewing and E for embroidery. If this is the case, re thread your machine with the pressure foot up and make sure the thread goes over the take up lever.
Dec 10, 2007 | Singer CE-200 Quantum Futura Computerized...
The thread keeps breakijng when I am embroidering
It could just be that your needle is blunt and you need to put a new one in. It is amazing how many different problems a blunt needle can cause. Hope its sorted now.
From Sewmad
Nov 04, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
