Question about Garden
What kind of Hydraulic Oil should be used in a Mitisubishi D4000 tractor
  • 3600 Answers
SOURCE: mt180d hrdraulic problem
Since you are not saying which hydraulic oil you want to change I will give you a site where you can log in and they can help you with the oil and any problems you have had since you didn't say what the problem was. You will have to become a member but costs nothing except your e-mail address’s go to http://www.tractorbynet.com/forums/mitsubishi-satoh/101519-welcome-hydraulics-forum.html and you can find what you need.
Posted on Jun 19, 2009
  • 252 Answers
SOURCE: My recently purchased used MT180HD tractor will
hi there joedorava
is there input to pumps , are there any leaks in the system either oil / air
have you purged all the air from the hydro units and wheel motors
if air is entraineed in oil , you may get alot of noise from caviatation in the pumps and wheel motors also heat , and vibration and no movement until all the air is gone
top up oil to correct level
caviatation can be quite destructive on pumps etc
i assume you used the correct hydraulic fluid for the unit in question
have you checked changed hydraulic filters when changed hydraulic fluid ?
other than that cant give any more info
cheers pauly46
Posted on May 25, 2011
  • 8 Answers
SOURCE: Where is the hydraulic oil
Its the transmission itsef, you fill it from under the hood between battery and steering console. Its a little black cap that lifts off tube.
Posted on Jun 30, 2011
SOURCE: What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Posted on May 31, 2012
  • 3519 Answers
SOURCE: What type of hydraulic oil goes in a 1954 massey ferguson farm tractor
The older tractors used type TCH which meant Torque Converter Hydraulic. That's sometimes hard to find now. NAPA has a product type TDH (stands for Torque converter, Differential, Hydraulic) and is appropriate. Regarding the pink color, some of the fluids come that way. It makes leaks easier to locate. Long live old iron!
Posted on Feb 22, 2015
Wat hydraulic fluid do i use for my ford tractor 6700 modelEC215 serial number B364256
First, whatever you buy be sure it is Transmission/hydraulic fluid not just hydraulic oil. The hydraulic and trans oil are the same oil. John Deere trans fluid will work, Case IH. Tractor supply has a fluid that works good, Traveller Trans/Hydraulic Renew. It is for older tractors.
Nov 14, 2016 | Ford Garden
I have a zd21 kabota mower. what kind of oil ges in the tube behind the right side fender? its says oil but doesnt specify weather its hydraulic or motor oil
engine oil goes in the engine which will be at the dipstick hole or filler cap on the engine
anywhere else on the mower will be hydraulic oil
Apr 28, 2016 | Garden
My recently purchased used MT180HD tractor will not move. I replaced all hydraulic oil,checked the clutch,and adjusted linkage. What next??? Are my hydraulic pumps bad?? Can a mechanical transmission be...
hi there joedorava
cheers pauly46
May 25, 2011 | Diesel Compact Tractor 4x4 20hp Machine ...
Transmission oil foaming and pushing out of dipstick tube during normal transmission operation. Transmission has been serviced - oil & filter replaced with OEM components.
Has the suction filter been serviced? And what transmission oil have you used? Is it John Deere hydraulic oil or hydraulic/transmission oil? Does the tractor have a loader?
Dec 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Jun 24, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
