Question about Dishwashers
What does E30 mean o the Fischer and Paykel dishwasher and how do I restart it.
4 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: problems with fischer paykel self cleaning oven
Hi and welcome to FixYA.com!
Here are links to the two most popular Fisher Paykel Wall Ovens:
OD/OS301:
http://www.fisherpaykelparts.net/partmanuals/545619C_Aerotech_UGM_USw1.pdf
OD/OS302:
http://fisherpaykelparts.net/partmanuals/599194C_Aerotech_ugm_USw.pdf
If neither od these is your model, let me know which one you have and I will locate a use and care guide for you.
Hope this helps and Happy Holidays from the FixYa crew!
Posted on Dec 15, 2008
pride applia
  • 232 Answers
SOURCE: F1 problem on Fischer and Paykel Dishwasher.
NO POWER TO LOWER DRAWER, CHECK POWER AT BOARD IN LOWER BACK CORNER BEHIND DRAWER,CHECK FOR BROKEN WIRE TO LOWER DRAWER,CAN ALSO BE THERMAL FUSE ON HEATER PLATE,COULD ALSO BE CONTROL BOARD IN LOWER DRAWER.GOOD LUCK there is a drawing taped inside behind the drawer. oops sorry about all caps prideapplianceser@sti.net
Posted on Jan 01, 2009
desayres
  • 10 Answers
Sounds like Clothes Washing Machine To Me!!--Methinks You have "Posted Incorrectly"--Stay Upright --Des.
Posted on Jan 17, 2009
Tip
How to take dishwashing liquid out of aid dispenser
I read a few tips on this site about the above problem.
Then rang Fischer and Paykel. My dishwasher is a two drawer.
They suggested using chux rolled up and pushing down aid dispenser.
After pulling out, throw out and keep doing this with a fresh rolled up piece of chux.
I did it about three times. Then I slowy poured some water in. Used fresh chux rolled up. Repeated the process a couple of times. Then repeated with dry chux, till it was all dry as much as possible. Then I poured half a cup of white vinegar onto the bottom of dishwasher and did a rinse cycle, checking for foam, every now and again.
The white vinegar stops the foam.
All seemed good.
Then I did an empty full wash "test". All good at the end. No froth at all during cycle.
After the "test" wash, I filled the aid dispenser with "rinse aid" not dishwashing liquid.
All up it took me about 20 minutes.
Thought I would pass on. And don't panic, (like I did). The woman at Fischer and Paykel was so helpful and said it is a common thing, so I didn't feel so bad.
on Nov 18, 2016 | Fisher and Paykel Dishwashers
Fischer and Paykel. Why won't it start?
hold down the lock button for 4 seconds and see if the light turns off.
if so then tada
Aug 10, 2015 | Dishwashers
How do I replace the outlet hose?
The exact steps depend on the make (brand name) and model of your dishwasher, but in all cases, you will have to pull the dishwasher out from under the counter. If it's an "American" dishwasher (Whirlpool, Kenmore, KitchenAid, GE, Frigidaire, etc.), you will see the hose clamp that connects the drain hose to the dishwasher, and it will be easy to disconnect the hose from the dishwasher. But if you've got a "foreign" dishwasher (Samsung, LG, Bosch, Fischer-Paykel), replacement is much more difficult and should be left up to a professional dishwasher repairman.
May 15, 2015 | Dishwashers
Keep blowing fuses
This means there is water collected on the base of the dishwasher cabinet under the bottom drawer. You will need to disconnect the dishwasher mains plug and take the bottom drawer out to dry the base out. Follow instructions in this manual (page 7 step 2) to remove the drawer.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jan 08, 2014 | Dishwashers
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Jan 16, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dec 29, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Problems with fischer paykel self cleaning oven
Dec 15, 2008 | 2006 Fischer MRX 650
OD/OS301:
OD/OS302:
Dec 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
