Question about Miele Washing Machines
Looking for part numbers for a Miele w1918 washing machine
  • YouFixit
    YouFixit Apr 23, 2017
    Which part are you looking for in particular?
SOURCE: need the operation manual
Here is a link for your manual.
mielemanuals
verno
Posted on Apr 07, 2009
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 123 Answers
SOURCE: miele novotronic w1918 wiring schematics
hi there ....the wiring schemematics can be obtained from meile with no problem .....if you can tell me what area in uk youn reside i can advise you where to obtain your diagrams
Sir Galahad
Posted on Aug 12, 2009
  • 1525 Answers
SOURCE: Fuse Box
there will be a glass fuse on the power board of the washer it might have cover over it good luck
shaun
Posted on Aug 15, 2009
  • 56 Answers
SOURCE: My Miele Novotronic W1918's drum is moving forward
sounds like your inner tub is broken. check your manual for the warranty. if there is no coverage left be prepaired for a hefty bill
Posted on Feb 07, 2010
Can I wire my Miele W1918 washing Machine to work on 120 . And if not can you walk me through wire set up.
if the machine is 240 volt system and the mains voltage is 110 volts you can use a step up transformer
Dec 25, 2014 | Miele Washing Machines
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
Novotronic washer w1918 jumps violently when transitioning from main wash to rinse 1-2 with 21 minutes to go to end of wash cycle
If the problem is consistent, FIRST check to make your machine is level. Also try cleaning the machine out with no clothes in it using white vinegar on a hot wash. If you're having a problem with high speed spin with NO load in it, it could be shaft/bearing related which would probably be too expensive to fix. Otherwise you could simply just be adding loads incorrectly or overloading it.
May 19, 2014 | Miele Novotronic W1918A Front Load Washer
Washer wont spin miele w1918
You can give Miele tech support a call, 800.999.1360, they can walk you through some troubleshooting and set up a service call if neded.
Jan 25, 2014 | Washing Machines
Water leak
first you should open the unit and find out if the leak is coming from a hose or the pump or maybe a crack in the tub
Jul 25, 2010 | Miele Novotronic W1918A Front Load Washer
My Miele Novotronic W1918's drum is moving forward and scraping on the door glass. It is also making a clunking sound when washing.
Feb 07, 2010 | Miele Novotronic W1918A Front Load Washer
Fuse Box
shaun
Aug 14, 2009 | Miele Novotronic W1918A Front Load Washer
Miele novotronic w1918 wiring schematics
Sir Galahad
Aug 12, 2009 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
