Question about HP Office Equipment & Supplies
Hp c4180 printer will not power on. Orange power switch and exclamation point are lit. Otherwise printer is dead.
  • 16 Answers
SOURCE: Dell 962 all in one printer
the yellow blinkin exclaimation point is usually an indication that there is a printer cartridge problem. It usually means the ink is low.
Posted on Mar 19, 2008
SOURCE: ink cartridge
we just installed a new ink cartridges..it keep saying install new cartrigde..and so it doesnt print anything at all.
Posted on Jul 01, 2008
jigsawbill
  • 398 Answers
SOURCE: HP 7410 - No display and orange exclamation point is lit
Unplug your power supply and leave it off for like ten minutes, then replug it and see if it will initiate itself, if not it sounds like serious malfunction.
Posted on Aug 25, 2008
SOURCE: I have a HP LaserJet 1320n printer and it will not
Possible Solution to your issue!
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
Posted on Feb 23, 2009
FixinFax
  • 3085 Answers
SOURCE: HP 6110 All-in-one printer solid exclamation point stay on
Probably not, sounds like a bad power supply.
Posted on Aug 04, 2009
C4180 shows 12345 on a orange
this is cartridge error. pls .. check carrige assyembly....or cartridge
Apr 06, 2010 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart C5180 All-in-One will not start, when I plug it in I get an orange exclamation mark and nothing else?
check if there is paper and also check the cartridges, if were necessary clean their contacts using a contacts cleaner.
Aug 11, 2009 | HP Photosmart C4180 All-In-One InkJet...
Printer problems
Not good, ma'am.
Try unplugging the power cord for 10 seconds.
Remove the toner cartridge, look for a jam.
Make sure the paper supply is pushed forward.
Jan 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP C4180 orange light
your cartage is now damage relapse it your problem will be solved
Dec 17, 2008 | HP Photosmart 4180 All-in-One Printer
Aug 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Ink cartridge
Jun 07, 2008 | Dell 924 All-in-One InkJet Printer
Hp laserjet 3050 all in one
Ok fine the same prolem with 3050 . Is haviong the some manufating defect . check your usb cable, reinstall the new driver from the hp site. if the problem dose't fixs pls call the hp help for replacment
Thank you
Mar 02, 2008 | HP LaserJet 3050 All-In-One Printer
26 people viewed this question
Seeker5211
Seeker5211
