Question about Garden
I just bought cm1640 cordless mower and it won't start talked to service rep today and was zero help what is wrong with it
    Top Expert:
  • Garden Master
  • 48,245 Answers
Brand new take it in for a warranty check
did you follow the user instructions and remove the plastic block from the battery terminal that stops it from going
flat in the shop before trying to use it
did you charge the battery for the required time before trying to use it
Posted on Apr 22, 2017
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
How to tighten belts on a gravely zt 60HD zero turn lawn mower
Todays belts are not as good as the ones we once bought and tend to stretch out quickly and easily. More than likely you need to replace them.
Aug 23, 2014 | Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
Homelite chain saw won't start
Not the way u want to but i have had luck heating the engine withheat gun. try hair dryer if u dont have a heat gun. Or pull plug out and clean lightly with emery clothe or ~400 grit paper. clean plug before reinserting
Jun 06, 2012 | Homelite Garden
Craftsman zt 7000 zero turn riding mower will crank but won't start and the starter get really hot
sounds like a safety switch problem. but maybe you can help me i have the same model do you have a lot of jerking when you start off of turn with yours?
Apr 10, 2012 | Craftsman Garden
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
A service rep was out and replaced the refrigerator evaporator coil today and the refrigerator is working fine. However the ice maker was not making ice, due to ice build up on the back of the ice drawer...
just a thought sometimes when the defrost has been set you have to go and reset the freezer temp. it should be around zero-f ..... when you reset the freezer temp you should hear it start up. if that dont work call the service company and explain over the phone you need directions to reset or turn it back on.. and tell them if they have to come out you shouldent have to pay because the freezer was working before they came.... and you should have no problems.... the last thing they want is an unhappy customer.. atleast the good companys... good luck i hope this helps
Aug 13, 2011 | Sub-Zero 561 / F
Poulan push mower won't start
Remove the spark plug and pour a teaspoon of gas into the spark plug hole then replace the spark plug and it will start.
Aug 06, 2009 | Poulan "Poulan" Push Mower
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
