Question about Nor-Lake Freezer Norlake Refrigeration 8' x 10' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
My walk-in's ceiling panel is dripping
My ceiling panel is dripping - I checked conderser coils, look good. The leak doesn't appear to be coming from the clear drain hose; but it is just below it.
  • Nor-Lake Master
  • 1,253 Answers
The coil in the conditioned space is called the evaporator.
If the water droplets are forming on the ceiling around the evap, it is due, most likely, to the defrost cycle being too long.
Defrost cycle: compressor stops, evap fans stop, electric heaters in the evap come on to clear any ice/ frost on evap fins/ coil.
The ice/ frost melts and some of it turns into vapor. As it hits the cold ceiling surface, it condensates into water droplets. Defrost cycle could be too long. Usually 4 time aday and no longer than 30 minutes should be enough unless there is high humidity.
There could be another cause.
Normally, after a defrost cycle terminates, the evap fans do not come on, due to a delay control. This prevents circulating warm are due to the heaters. The compressor comes on and cools the evap down to, usually 20 degrees or so, and then the fans come on. What could be happening is, the fans are coming on too early and blowing the water driplet off the evap and onto the back wall of the unit.
A third item, is to be sure that the condensate drain is "P" trapped. The prevents warm, outside air from being drawn in and causing exess frost build up, thus excess water and vapor.
Good luck and hope this helps
Posted on Jul 25, 2009
Why would condensation be running down the sides,or water dripping from bottom?
should be a small plastic tray funnelling from under the fins in back to a small hole n hose out the back of unit check owners manual if possible,..
Jul 08, 2014 | Delfield Freezer 6125XL-S
Walkin freezer has ice building up on the walls and ceiling. Defrost is working and since I replaced it the temperatue control works. Setpoint is 0 degrees f. I did notice that during defros the heaters...
If you are seeing droplets on the ceiling and runs down the back wall behind the evap I got a reason.
The unit is probably staying in defrost too long. The frost on the evap melts and some of it drips onto the heater elements. This turns it into steam which rises and hits the cold, metal ceiling. The steam condensates into droplets and whent the system comes back on, they freeze. This can also cause the runs down the back wall too. Seen this happen alot. Check to see that the fan delay is working, It causes the evap fans to come on only after the evap chills down to about 20 degrees after a defrost ends.
Hope this helps ya.
Oct 23, 2009 | Freezers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Electrolux premier eco freezer leaking. Water appearing on the floor. Ice building up inside the freezer.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help
Oct 11, 2009 | Freezers
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Mountain of ice in walk-in(floor), around the parts(ceiling)
No choice but to move your food to a secondary unit & defrost the walk-in. If you go chipping around your condenser you risk more damage. Hopefully you have seperate breakers for you walk-in vs other cold storage areas.
Apr 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My walk-in freezer is developing stilagtights (ice castles) on the floor and cieling in front of the evaporator coil.MY drain pan is not plugged when I pour water down it.
You should check for air leaks around the door gasket or any other openings in the compartment such as where pipes or wiring is going through the wall. It sounds like a moisture problem from moisture being drawn into the compartment pass door gaskets or access holes.
Mar 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Norlake walk in fridge
Yes if the evaporator drain is blocked or not attached correctly it causes the humidity to remain in the refridgerator. Just opening the door will cause the warm are to enter and cause the symtoms of rain if the water is not taken out the drain properly.Hope this helps JT
Oct 15, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
303 people viewed this question
Top Nor-Lake Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
