SOURCE: toshiba 2141tb tuning
there is a menu that has autoprogram in it, use that and itll scan all channels and memorize the viewable ones. Sometimes it is a stand alone button behind a door or it is in the setup menu. Make sure your antenna is plugged in. If you have cable, the only channel that may be stored is 3.
SOURCE: Problem getting cable to tune in to Daewoo TV
you need to get back origenial daewoo remote control to do the setup input & output. good luck!
SOURCE: grundig wf823020a tv tuning
if you cant get it with the remote try the front panel if it has any buttons besides power go to menu and see if it's there
SOURCE: Tuning a Channel
To Tune in Philips Machline TVs
Without using remote. Open panel on front of tv
1-- Press the menu key. --screen will now display 5 menu options--
2--press the down arrow key untill Install is highlighted
3--press the vol + key -- now install options appear (language--autotune---mantune--channel no--store)
4--press the down key to select the function required (Autotune is best) Manual is ok if the tv station's freq are known and they can be then given a ch no
5--press the + key to start the function selected ---tv will auto tune in tv stations when completed
6--press down arrow and highlite store then press ok
7--Press menu to clear menu off screen
SOURCE: Have a Pioneer PDP508XDA its asks for a password when tuning
Default password is always 0000
