Question about Garden
I have a low-pressure sprinkler system in my flower bed. I have orbit distribution heads, tubing and fittings. I can't get the tubing to stretch enough to fit over the fittings. 1/4" system.
Been using this system about 10 years. Now this problem
    Top Expert:
  • Garden Master
  • 49,277 Answers
If the hose is new compared to original installation, it looks the same but could be metric sizing and that will be your problem
it is possible if you use boiling water to help soften the plastic tubing but the correct size tubing is a better fix
take a fitment bit along and try it in the hose before you buy it
Posted on Apr 22, 2017
Have a system 7 heads 5 feeding off trunk line two off of two tee lines. the system is feed by 3/4 pipe,it worked fine for 1 year know it won't always pop the heads.
Either the pressure has gone down due to a leak or the heads have gotten dirty inside and need to be cleaned out so they again pop out fully.
Mar 06, 2015 | Orbit Satellite Impact Sprinkler Head
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Sprinkler will not pop up
Sounds like "Sure pop" was misleading. Try unscrewing the top or entire sprinkler then the top remove the spray nozzle to access the spring. Stretch it out longer and re-assemble the sprinkler screw it back in place with the spray notches on nozzle facing are you want covered. This should solve the problem if not, replace the pop-up.
Jul 15, 2013 | Rainbird Sure Pop 600 Series 2-1/2" Pop Up...
How do I adjust sprinkler head properly
Check to see if the small slotted screw is flush with the top of the spray nozzle. If so, it has been manually lowered. Turn the screw counter clockwise until it stops, be sure to hold the nozzle to keep it from turning. If no, unscrew the nozzle and remove debris from around filter. Tell the gardener to just mow the grass and not to touch the sprinkler system he is usually why it was turned down 9 times out of 10. If he says "No touch, No touch. He is lying fire him.
Apr 13, 2013 | Orbit Sprinkler System 2-inch Soft Top...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
