Am trying to hook W33001 TV to MOHU antenna. Attached antenna via coaxial cables TV and set source to "antenna" but don't know how to scan channels to see what, if any, antenna will pick up.
    Top Expert:
  • Televison & ... Master
  • 40,335 Answers
Channel scanning could be part of the initial set up procedure.
Posted on Apr 22, 2017
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
My Mohu Leaf HD antenna only pulls in one channel and should pull in over 20. I live in Plano, TX just north of Dallas, TX. I don't know what to do. I put the antenna in a good position and got nothin
The antenna may not have sufficient gain to detect the other channels. Is it amplified? You may have to try placing the antenna in different positions to receive different channels.
Nov 25, 2014 | Mohu Leaf HDTV Antenna
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Did attatching HD Antenna fry my HDTV?
"the screen is nearly constantly with the exceptions of..." What does that mean?
If your antenna has a power supply it may have malfunctioned and fried your TV's tuner. Forty inch flat screens go for about $400 and up these days.
It could also be a coincidence, that the TV was expiring just when you hooked the antenna up.
Nov 04, 2013 | Televison & Video
Okay, I purchased a TCL L40FHDF11TA 40-Inch 1080p 60 Hz LCD HDTV 2 1/2 years ago (2 year warranty) and it worked fine until I cancelled my cable subscription and hooked my set up to a new Mohu Leaf HD...
if you can open the back cover then tried to resoldered the main board which may have loose contact using a soldering iron. if still with dim picture then you may check the back light.
Sharp aquos 60 inch. Setup ok went thru ez scan for channels then not sure if i hit something getting settings right but now all it does is repeatedly tell me to search for channels even right after it...
Look in the menu to see if in catv or cable band or air band for antenna and you do have a way around this if using cable box or sat box---connect box via the jacks on the rear of the box (component or composite--component being better) and hook up to the correct matching input on rear of set--select that input on the set and change channels etc via the box.
Also try to unplug set for a short time and go through the setup again, be patient as a channel scan can take several minutes in some cases
Let me know what happens of if you have questions
Dec 06, 2012 | Televison & Video
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
    You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
    What is the model number of the TV?
    May 15, 2011 | Televison & Video
    Connecting antenna -- No Signal
    Hi Shelly_Eddie,
    Here are a couple of things to try:
    Is the TV set to antenna or cable? Use the menu settings
    Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
    Reset the TV and do a channel scan, unplug and see what happens.
    Let me know how you make out. Good luck.
    My Website
    Jan 28, 2009 | TruTech PVS31170S1W 17 in. LCD Television
    Televison & Video Logo
    46 people viewed this question
    Top Televison & Video Experts
