Question about Garden
Looking for a carburetor Po4lan Pro Weed Eater Z5CC High Output S-07929N400495-1 M- pp125
SOURCE: carburetor adjustment weed eater fl sst 25,will
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
Posted on May 21, 2009
carlsbiz
  • 1124 Answers
SOURCE: weed eater stalling
Need to get the carb rebuilt..
Posted on Jul 14, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
  • 5 Answers
SOURCE: I have a Echo Weed Eater, it starts and runs, but won't rev up
you can take the screen out altogether-ive done that for almost 20 years.That is probably your problem.You can also change the fuel filter in the gas tank.There is usually enuf slack in the gas line in the tank that you can get the filter to the gas tank opening and hold it w your fingers or pliers and remove it.Be careful with pliers to not gouge fuel line and just pull filter firmly off fuel line.There may be a tiny metal ring that helps hold fuel filter on to fuel line.Try to kind of hold it in place as you pull filter out of fuel line.If you lose it its not a big deal.Most filters fit snug onto a fuel line anyway.-A good way to get the filter to the mouth of the gas tank to work on is to empty all the gas and take a metal clothes hanger and bend it so you get a little hook in it and kinda "fish" for the fuel line w filter attatched.Within minutes you'll figure it out and get the filter up to the mouth of the gas tank where you can work on it.If you dont have enuf slack to work you can disconnect the fuel line at the carb and pull yourself a little slack.Dont go more than about 1/2 -3/4 inch though.----along w the muffler screen(located behind plate that is attatched to muffler with 3 small screws)(check plate itself for ability for air to pass thru-can clean it out with tiny screwdriver)-you can also take entire muffler off(two allen screws)that reveals a look at port where all the exaust comes from.If that area is choked with carbon you'll have a problem.Some weedeatwers get it bad some dont.So...check clean or remove(screens clog up fast) muffler screen located under plate thats attatched to muffler-----while plate is off check it for carbon buildup(you can hold up to the sun and see if sunlight goes thru it-that will tell you)-------take muffler off and look at exaust port(if dirty scrape carbon carefully out-turn machine upside down,tap with something,etc...no biggy)-----fuel filter.Also check air filter though probably not your problem unless its totally caked with stuff or getting soaking wet somehow.The only two main other things would be a plug or the thing attatched to one of the gas lines called a vent-just a little thing that pops on to the end of a line.I dont think the air filter ,vent,or plug is your problem-especially the vent or air filter.Its probably exaust related or fuel filter.---make sure youre gas mixture is right and make sure the gas isnt real old.---Ive had echos for 20 years-hope it wasnt too much to digest.Its all simple really-was just tryin to be descriptive to help u as much as possible.good luck
Posted on Jun 29, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Can't start my Poulan Pro weed eater. Never had
Hi jsbivens..
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a Awl/Nail, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 22, 2011
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
What is the proper way to adjust the high low carburetor setting on a Poulan Pro weed eater
Both should be set at 1 and a half turns out to start. Turning the screws out will richen. Turning in will lean. If its hard to start or boggs/ dies when you throttle then its lean- turn the low out another half turn. If it revs up for a minute then slows down richen up the high. At full throttle you still want to hear a bit of a cackle- adjust the high
Jul 08, 2014 | Garden
Poulan pro pp125 on/off switch
Your suspicions about the on/off switch may be correct.
Nov 20, 2017 | Poulan Pro Pp125 25cc Gas Straight Shaft...
ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
My poulan floods the carburetor
THE FLOAT DIAPHRAGM AND NEEDLE SHOULD BE REPLACED OTHER THINGS TO CHECK... CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
New poulan pro will not start
when I bought mine. The weed eater didn't start right away so I took it back where I bought it and I had them look over it. when reading the manuel It said that it might not start right away becuse the fuel mixture needs to be adjusted on the pro prolan pp125 weed eated. so we utilized what we had around us and found a tube. adjusted it and it started right up.
May 22, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
My Poulan Pro 32 cc high output engine (with either the small chain saw or weed eater attachment) is relatively easy to start but after a few minutes it stalls out. Restarts easy but continues to stall out...
hey its broblably a clogged up carburetor which is not letting your engine **** up gas from the main fuel line. my advice is to clean all the filters and passage ways inside the carburetor. Also you may have to replace the diaphram in the carb a diaphram is a thin piece of material that basically pumps the gas into the engine also with the help of the compresiion of the engine sucking it in
Mar 07, 2010 | Poulan Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
