Question about Coffee Makers & Espresso Machines
Have a Jura giga 5 that says refill the water tank that is full
3 Suggested Answers
SOURCE: Refill light is on, but the water tank is full
In the manual it says that you should clean the heating element. Unplug the machine, lift off the water tank, pull the lever under the tank and lift off the power unit side. If there is too much build up on the element from mineral deposits, the refill light may remain on.
Unfortunately, I have cleaned mine, soaked it in vinegar, made it look nice and new...and it still doesn't work. I am really annoyed as I have not had this humidifier long and have taken really good care of it. I do not want to throw it out. I am going to call customer support and find out if there are any other solutions. (I got a new one for Christmas and do not want to open it until I am sure that it is not fixable!)
Posted on Dec 26, 2007
  • 63 Answers
SOURCE: Refilled tanks 4-5 times and
Have to give a better explanation of what equipment you are using and whether it is electric or gas powered.
Posted on Sep 22, 2010
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Aug 18, 2014 | Jura Capresso Impressa S7 Coffee Maker,...
Jura impressa x7 keep getting report fill water tank
make sure the water tank is full! there is a small float in the tank that moves up and down near the bottom, make sure this is up and not stuck down.
Feb 05, 2014 | Capresso Jura Impressa X7 220v
Error code 15 on a jura giga professional x7 coffee machine
Dear sir ,
Please help me, Now my coffee machine Jura GiGa X7 Professional , When i start turn on machine maybe 15 second it turn off by it self.
Jan 11, 2014 | Coffee Makers & Espresso Machines
Add water message on constantly
remove tank clean with hot water, rinse and shake you should hear a rattle in the bottom of the tank. if you dont the the small black float built into the tank side wall is stuck. once free it will work fine.
Jul 05, 2013 | Jura Capresso ENA 4 (13421)
My Jura impressa c9 keeps telling me to fill water tank when it's alteady full. Help!!! I need coffee!
This just happened to my c9. Tried cleaning and it wasn't dirty. I took the water filter out, pushed on the water tanks spring and it works fine now.
Apr 10, 2013 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
75 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
