My bosh max classic won't stop filling with water
    Top Expert:
  • Washing Mach... Master
  • 45,659 Answers
Replace the inlet water control diaphragm or solenoid
Posted on Apr 21, 2017
Bosh classic washing machine fault no F 21
Kindly read the manual or see a specialist.
Jul 21, 2016 | Washing Machines
I have A bosh SKT 2052 Will not fill up to start the cycle
see the following causes:
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher) see diagram
2) faulty float switch, test for open or faulty.
see the diagram attached.
God bless you
Jul 11, 2012 | Bosch 22 in. SKT5102 Free-Standing...
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Bosh classic 1200 won't fill with water,
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 22, 2011 | Washing Machines
My bosh exxcel disher dose dot fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Dishwashers
Dishwasher fills with water... stops...(when it should be washing) then drains. Seems like timed cycle is working. justdoes not wash.
you have a sensor and it is restricted behind the bottom panel you see a rubber hose about 1/4'' in size remove and blow through it unless it a Bosh unit some how water gotten into the motor area this is cause by a plugged drain hose
Aug 22, 2009 | Frigidaire Dishwashers
The drum won,t go around or spin BOSCH Classixx 1200 washing machine
BOSH WFL 2260 SPINS OK BUT WASHING CYCLES DO NOT WORK. FILLS WATER OK
Sep 26, 2008 | Bosch Washing Machines
DISHWASHER
Make sure you have water coming to the dishwasher. Next check your dishwasher float. Make sure it is not sticking. If not you could have a problem with your fill valve. Check for voltage at the fill valve if you have 120V then you need a valve the solenoid is defective. Replace it.
Dec 24, 2007 | Dishwashers
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
