Question about Akai Televison & Video
How do I get rid of blue lines on tv screen on an akai bn59-00347
  • 923 Answers
What blue lines? Do you want the blue electron gun turned completely off?
Posted on Apr 21, 2017
Testimonial: "If your looking at tv and its on, there is about 5 tiny blue lines from the top of tv to the bottom in the middle of tv."
  • Charlene Seifert Slaybaugh
    if your looking at tv, there is about 5 thin blue lines from the top of the tv screen to the bottom.
  • solver2010 Apr 21, 2017
    Are the blue lines completely vertical, or are they on an angle? Are they there no matter what channel you're watching? Is the TV a picture tube type, or a flat screen model?
Blue line, blue out of sinc along botttom 1/4 of tv
If this is a Rear Projection T.V, your CRT is going bad. You can take the front cover off and make slight adjustments on the blue screen control to get rid of any lines, as far as the blurriness of blue, that part is 500 dollars to fix. The most you can do is just get rid of the lines. There's a black box. Make sure you are very gentle with your adjustments. Just turn it back to how it was if the screen shuts off. I recommend turning down the brightness of the T.V. before you do this repair.
Jun 18, 2011 | Panasonic Televison & Video
I have lines on the bottom of my 57in rear projection hitachi tv how do i get rid of them myself
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from
Sep 23, 2010 | Hitachi 57F500 57" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
My projection screen has blue and green lines across the screen id do not know how to converge the lines akai screen where do i go to fix it
Hi, thank you for visiti fix ya.
Your tv need convergence ICs service ( replace).
Can you send me model number tv, please?.
Thank you
Jul 25, 2009 | Televison & Video
Authorized Repair Centers for Akai Flat Panel TV
first try to reattch all coneection to your televison.
then open the back side cover of your tv then reattch all connectiuon there .
Also clean dust from all circuit.
Apr 23, 2009 | Televison & Video
Vertical line on rear projection TV - Akai PT4298HD
this is an indication of a burnt crt. unfortunatly to fix this the crt will need to be replaced. such a repair is something i would recomend to a non tech. theres adjustment issues
Oct 30, 2008 | Akai PT4298HD Rear Projection Television
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai PT 5299 HD Rear Projection TV
That sounds like a high-voltage splitter, failure!
Dec 18, 2007 | Televison & Video
Vertical Red Lines
Oct 08, 2007 | Akai PDP-4216M 42 in. Plasma Television
Blue Vertical Line- Akai PDP4298ED
I have an Akai PDP4273M that developed the same problem. Checking around some of the av forums, I found a couple of threads that indicated it could be dust or bad contact around the ribbon cable connections on the video control board. I removed the back, loosened the ribbon cables on the board and used my small compressor with an air gun to blow out the dust all around the board and the ribbon connectors. Reconnected everything, turned on tv and stripe did not come back. Problem fixed! Nice and cheap solution.
May 28, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
48 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
