Question about LG Heating & Cooling
LG minisplit LMU240CE dual zone won't run, CH33, compressors replaced + both PCB main boards + caps. Ran 12 hrs and quit. Now fan stays on 5s then nothing happens until 5 trys then CH33 again.
22yooper
  • 828 Answers
SOURCE: Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Posted on May 31, 2008
CMV9
  • 594 Answers
SOURCE: GE Profile PTS25LBMARWW - Power, but no Cold
yes the mother board is located under the plate in the back.. but when you replaced the relay did you put on a 3in1 relay or a manufactured relay?
Posted on Aug 01, 2008
huuum
  • 750 Answers
SOURCE: warm fridge cool freezer
Hi folks,
IS, the freezer so packed full with packages that they are covering the air vents in the freezer that must be open to share the circulation with the fridge?
Let me know!
If not keep calling the server and pay him only when he fixes it!
Posted on Sep 20, 2008
  • 400 Answers
SOURCE: lg minisplit heat pump will not heat
You may want to check that the pressure switch is not functioning? Secondly there is also a thermo sensor on the condenser coil which could be faulty.
Posted on Mar 04, 2009
  • 24 Answers
SOURCE: amount of time the compressor and fan stay on
No, that's not too long. It takes a long time to bring the temp in there down from room temperature to around 38 degrees and zero degrees in the fridge and freezer, particularly with the smaller, energy efficient compressors we now have in most of our appliances.
Posted on Nov 08, 2009
Magic Chef Dual Zone Beverage Cooler...top zone works, bottom zone stopped working
What is the model number I can only guess to an answer not having the model number. Check the voltage that was feeding the bottom fan and top fan
Contact Me Here
Appliance 911 Sea Breeze
Nov 18, 2015 | Refrigerators
My Goodman DSZ160361AE doesn't run. When I start it up it will run for about 4 seconds then shut off. I get an error code of 7 yellow blinks which means run circuit or compressor windings
Get rid of the hard start cap. Hard start capacitors should never be used in conjuction with normal compressor operation. Contact your local dealer for goodman and find the correct dual capactor for your machine and install it. Odds are your dual capacitor is either not functioning properly due to over voltage strike or it is the wrong size. On the wiring to your compressor, black is normally common and lead directly back to your main contactor. The red wire is the running lead and again normally goes to the c connection on the dual capacitor which leads back to the other side of the main contactor. The remaining wire on your compressor goes back to the herm connection on your dual capacitor. You may have swapped the wires for your power supply to your capacitor. I did this once and I figured it out about 5 hours later after I performed a wire by wire check against the wiring diagram. If you switch the wire around you turn the start windings into run windings and vice versa. They are not designed to be interchangeble. Just check your wiring against the diagram and the problem should clear up.
Hope this helps.
Oct 07, 2014 | Goodman Manufacturing Goodman DSZC160361...
My LG LMU240CE (serial number 707KAJP00028) needs a new compressor. Please advise whether the part number is 520UGHK2AA or 2520UGJK2AA or whether it is some other number. Thank you
you will need to take the unit apart and the compressor will have the number and serial on it, this would be the outside unit with the fan. Hope this helps tim
Sep 30, 2010 | LG LMU240CE/LMN120CE Air Conditioner
My compressor cooling fan quit- the compressor still runs. I unplugged the unit then plugged it back in. The cooling fan ran for about 15 seconds, then shut off again. Is the problem with the main control...
The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
Jun 23, 2010 | KitchenAid Superba Architect KSCS25INSS...
Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Jun 13, 2009 | Goodman CKL24AR24 Air Conditioner
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Heating & Cooling Logo
35 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
