Question about Bosch Washing Machines
Suds blocked pump on bosch 800 series, tried to drain from drain hose, not much came put
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
I dont know this machine but open at the back, look under the drum there might be a chamber witch have a non return ball the chamber could be blocked
Posted on May 10, 2017
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
There's a pump clean out located behind a round panel near bottom of the machine in front. Using a shop vac, empty water in machine. Remove cut out to expose pump filter. Turn pump filter counter clockwise slowly to release rest of water and vac it up. Open completely and clean debris from chamber. Reassemble, you're done.
Posted on May 09, 2017
    New Friend:
We can fix it for you if you need our assistant please whatsapp at +971507393783
Posted on May 06, 2017
    New Friend:
  • 12 Answers
More then Likely there is more then just a suds lock small objects can build up loose change all can be in pump housing poss even damaged prop on pump it self need full model # and serial # to say much more
Posted on May 05, 2017
    New Friend:
Only had mine about two months and it works fine so can't help.
2 Suggested Answers
  • 327 Answers
SOURCE: Bosch Nexxt 800 series. We have continued problems
Hello,let the machine rest for a while so suds can disappear then unplug the unit for 1 min then plug it back in it should drain by its self if not do not select wash cycle but a spin/drain then you should hear the pump running, if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer, that way if water does not come out you have to access the pump and pinch off the drain hose from the tub and remove the object from the pump, be careful that you don't have a mess with water leaking from the tub good luck.
Thanks
Posted on Jun 03, 2010
Have e13 error code on washer. It won't drain or spin and I have clothes in there. How do I unlock door?
The code is related to it not being able to drain. The most common cause is suds in the drum from the wrong detergent. One of the other things that can cause this is the drain pump is plugged with something like a sock or other debris. If you want to drain it, you can try to move the drain hose to a lower level and see if gravity will drain it. This might not work if something is physically blocking the drain. You can also use a wet and dry vacuum cleaner to draw out the water through the drain hose. IF that does not work then you have to remove the bottom panel under the door and locate the drain cap. WHEN YOU REMOVE THIS ALL THE WATER COMES OUT. Get ready with something to catch the water. When you take the plug off, there is a filter or trap that you can clean. Once you have done this then you should be able to run the rinse and spin drain to get the machine back in order after you put the plug back in.
Aug 29, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Is there a way to reset the computer my bosch 300 nexxt series washer?
turn off THE POWER by c. breaker, wait by 45 seconds, and turn ON again and try it.
God bless you
Jul 10, 2013 | Bosch Nexxt 300 Series WFMC2201UC
Washer machine will not drain
Check for clogging in your drain hose, block inthe ddrain valve/ drain pump and foremost the voltage to the drain pump must be present when the machine program is reached.
If not the controller can be defective.
Sep 14, 2010 | Maytag Washing Machines
Bosch Nexxt 800 series. We have continued problems with the message "suds or blocked pump" we use HE detergent.. what else?  I have drained it once.. it seems that it continues to not pump out the...
Thanks
Jun 03, 2010 | Bosch Nexxt 800 WFMC8401UC
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water will not drain out of washer (bosch nexxt 6400). Will spin if on cold wash but not on spin. makes a clicking noise while trying to drain
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Mar 14, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My bosch nexxt wont drain and flashes e04 checked imoeller and cant find any clogs impeller spins freeley
Feb 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch wfr2460
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Suds or blocked pump is a message popping up. the door to the front washer won't open as it says the water level is to high.
let it rest a while so suds can disappear then unplug the unit for 1 min then plug back in it should drain by its self if not do not select wash cyc but a spin/drain then you should hear the pump running if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer that way if water not come out you have to axcess the pump and pinch off the drain hose from the tub and remove the object from the pump be careful that you don't have a mess with water leaking from the tub good luck
Aug 27, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
Washing Machines Logo
218 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
