Question about Home
Bathtub has a flapper above the drain to open and close it. How do you loosen it?
2 Suggested Answers
  • 82 Answers
SOURCE: how do you get the
they unscrew counter clockwise its easier if its poped up
Posted on Dec 10, 2010
WHIRLPOOL Washer #LA5578XTW0 won't drain
Is the end of the hose where the water comes out into the sewage up at the top height of the machine? on some machines if it is lower than the top height (not lower or heigher but level with the top of the machine) it automatacally closes off the drain Flapper preventing the water from draining.
check the hose; disconnect the hose from the machine and take a deep breath and blow through the hose as hard as you can. if there is no obstruction, replace the hose ( bet there is a sock stuck in the drain hose).
with the drain hose off~check where it connects to the machine, some machines have a "flapper" that closes when the machine is in operation and opens when it drains. Unplug the machine, then see if the flapper is loose enough to open and close. Also check to see if something is stuck behind that "flapper" preventing it from opening to let the water drain.
Nov 10, 2016 | Whirlpool Washing Machines
How to remove a bathtub drain plug?
There are two designs of these drains. One has a small set screw that has to be loosened to allow the plug to be removed. The other has a threaded post. By closing the drain plug and then turning it counter clockwise the post will unscrew and the drain plug will lift out. Hope this helps.
. Bob
Jul 20, 2014 | Westbrass 1-3/8 in. Brass Twist & Close...
Jet bathtub wont drain
Seems that the mechanism on the knob that is supposed to control whether the drain is open or closed has become disconnected or is stuck in the closed position. You could try to force it open by grabbing the knob with a pair of pliers and turning it, but you may risk damaging the knob, or you could dismantle the knob and see if you can reconnect whatever came apart
Dec 11, 2013 | Home
Incompete toilet flush with unusual Toto flapper
You problem is that the weight of the flapper is too much when it is supposed to be floating. I think there is an adjustment you can make on it to close it up some or try shortening the chain a notch or two to give it a higher lift in the water. Then the buoyancy of the flapper would allow it to stay suspended in the water longer thus allowing a more complete flush.
Jan 14, 2013 | Home
DU2100B: Looking for a repair/service manual for this. My problem is that the dishwasher will fill with water, then immediately drains. It rarely does a complete cycle without doing things out of...
I don't believe that a service manual exist i have included a image of the parts breakdown for the pump asm. and while taking look at it i believe the the drain solonoid is hanging up,or the drain flapper in the pump asm is hanging open The solonoid is shown is that image as item #5 it connects to the drain flapper shaft item #13 and the actual flapper is number is item #34 and has a sping thats suppose to close it item #35
one of those is staying open not allowing the water to stay in tub on wash cycle
http://www.searspartsdirect.com/partsdirect/part-model/Magic-chef-Parts/Dishwasher-Parts/Model-DU2100B/1429/0130000/X2905652/00006?blt=06&prst=0&shdMod=DU2100B
Good luck,i hope i have help you to figure out what is wrong with your dishwasher.
Gene
Aug 13, 2011 | Magic Chef Dishwashers
How do I Remove Magnesium Anode ?
The following page has instructions and a link to a video:
http://waterheatertimer.org/Replace-anode-rod.html
How to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read owner's manual to see location of anode rod
See list of water heater manufacturers and brands to find product manual.
Before starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water line.
Open drain valve near bottom of tank,, and drain 2 gallons of water.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Use 1-1/16" socket for hex head rod
Rod will be rusted in place, use generous amount WD-40
WD-40 spray is flammable and will burn so be careful around heat source.
Loosening rod: go slow and check that water does not seep up when loosening rod because hot water can spew out hole if tank is very hot ... it is important to drain enough water out of tank to avoid accidental scalding.
Install new anode rod: One source says/ use pipe compound on thread instead of teflon tape. Other sources say use teflon tape. Either way, tank metal and anode metal must meet, so rod will work.
Dec 23, 2010 | Water Heaters
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 | Home
Makes noise but jets do not work
Is intake clogged? sounds like impeller has come loose from pump if not.Take a garden hose and feed water back from a jet(closing/plugging others) to see if it flows back out intake checking for obstuctions. Are jets all the way open and water level well above intake?
Oct 04, 2010 | American Standard Cambridge 5' Americast...
My bathtub drain is American Standard circa 1927. The tub stopper is actuated by turning a knob connected to a linkage connected to a rod, connected to a yoke which threads onto a sleeved pipe which...
your close to figuring it out,
I would guess you have a hair clog in the trap. they have inexpensive plastic rods (like a long zip tie) with serrated edges on it to capture the hair. Home Depot or Lowe's or Menards will have these
Jun 28, 2009 | Plumbing
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
