Question about Echo Garden
Air gap coil to fly echo cst 610evl - Echo Garden
    Top Expert:
  • Echo Master
  • 47,827 Answers
Close as possible with out touching --around the .005" measurement
Posted on Apr 21, 2017
What is the gap for the fly wheel to cdi on a 4600 echo chain saw
The easy way is to put a piece of sand paper between the coil and magnet.Put it in tighten the coil and pull out the paper.
Feb 26, 2011 | Echo Garden
Need the air gap between the ignition coil and the flywheel for an Echo PB-251 leaf blower
All magnetos work best with minimal air gap. Gap it with the thinnest piece of paper/plastic that you can remove from the gap. Spin it, examine flywheel for evidence of rubbing. If it's good, start it and zoom it a couple of times, shut it down and check again.
lp
Feb 05, 2011 | Echo Garden
Igntion coil on echo trimmer went bad, replaced with echo blower coil . there is a small difference in design but now have ignition. Engine still won't start.
Make sure the air-gap between your used blower coil module and the magnets on the Echo's flywheel is about the thickness of a regular business card. That is about .010"-.016". The gap HAS to be present in order for the module to produce the spark.
Oct 01, 2010 | Echo Rapid Loader, Trimmer Head
I am replacing a bad coil in my Echo SMR 2100. I need to know the air gap between the coil and the flywheel.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH
Aug 06, 2010 | Echo Garden
Need a manual for cst -610evl
It is not listed here, but if you type "CST610EVL" in the search window 4 manuals magically appear.
EchoUSA
http://www.echo-usa.com/documentation.asp
If i can help further please reply brlow. I this was helpful.
Lou
Jan 27, 2010 | Echo Garden
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
Echo SRM 1501 trimmer has minimal fire. Feels very slight, will not fire thru plug
If this is a solid state ignition ( black box mounted right next to the fly wheel)check for rust on fly wheel and coil/ignition.Sand with light grit sand paper if nessesary. Make sure to reistall with the same gap between the two parts.note the gap at this point could also be wrong.Also check to see if the clip inside the boot where the spark plug conects is not bent and that it is conecting properly. If this is a points ignition system then its basicaly the same steps.Clean contact pionts check plug boot for good contact. Or could be bad coil.Be sure you are using a plug with the propor heat range.
Jun 07, 2009 | Echo Garden
Garden Logo
48 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
