Question about HP DeskJet F4280 All In One Printer InkJet
I have a HP Deskjet F4280 All-in-one. After installing a new color cartridge, no blue ink would print. I ran all the tests, cleaned the cartridges using the HP solution program. Still no blue. And it won't align without all the colors. Black ink works fine.
  • rachel_arizo Jul 28, 2009
    No, it was not refilled.
  • 684 Answers
Was that a refilled cartridge???
Posted on Jul 24, 2009
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Why does hp deskjet f4280 print pages with missing text and lines?
Ink lines are clogged, sometimes unfixable, Try deep cleaning cycle.
May 15, 2014 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
Ink is stuck in the printer. I can't get it out.f4280 deskjet
I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
To replace the print cartridges
1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
2. Open the print cartridge door.
The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black print cartridge
4. Pull the print cartridge towards you out of its slot.
6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing the black print cartridge, slide it into the right slot.
Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
My F4280 HP all in one wont recognize the refilled cartridge.
hello, attempt to clean the sensors on the bottom of the cartridge with some kind of solvent and q-tip. If the ink cartridge has sat awhile before you refilling it then the jets will be clogged dry and you will need to purchase a new one for your printer.
Oct 02, 2009 | Office Equipment & Supplies
New f4280 no blue ink as well
Yes, new cartridge would solve the issue. Also, if you want any help for replacing cartridges, please visit this link:
HP Deskjet F4280: Replacing Cartridges
Jul 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hi, I have an HP F4280 printer and the orange light of the color ink level is always lighting so i can't print anything (I am sure that my color cartridge is not already empty). What can I do? Oh yeah,...
There is only enough ink in the HP 60 cartridge to print approximately 200 pages. Also, the ink stored in the cartridge can dry quickly even it it's not used so you may be out of ink or the ink in the cartridge has dried up. Refill your cartridge with a kit or replace it with a new one. The ink level indicator is only an estimate any way. See pg 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jun 05, 2009 | HP DeskJet F4280 All In One Printer InkJet
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Jan 29, 2009 | Office Equipment & Supplies
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
464 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
