Question about Garden
Where is the Gearbox filler plug on a mtd rototiller#135202?
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
  • 4 Answers
SOURCE: Topping up gearbox oil on 99 Hyundai Lantra (manual)
You can actually do it from the top if it is similar to a 2001 Elantra??? On your right center of the tranny, there should be two big bolts I believe a 17mm one on the bottom left the other top right of the other. The bottom left is the drain plug the top right is where you fill it. If you want to make things easier you can remove the air cleaner and the air cleaner housing then unscrew the sensor on top of the tranny you can poor it in from the top. You will need to then unscrew the fill hole (Top right bolt) Pour the lube in to the hole where you had taken out the sensor until it pours out of the fill hole. Sounds like more work but by doing this you will avoid making a mess trying to fit the squeeze bottle into the tiny hole. Hope this makes Sense????
Posted on May 17, 2009
  • 454 Answers
SOURCE: I have a craftman rototiller 5 hp model 135202
If it is a rear-tine tiller (tines behind the wheels), that's the way it is supposed to work.
Posted on May 01, 2010
Testimonial: "thanks for the help. may GOD bless you and yours thanks again .."
  • 221 Answers
SOURCE: have a rototiller it moves ok but the tines do not
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Posted on May 06, 2010
budgie140
  • 501 Answers
SOURCE: manual gearbox filler
according to my book,the speedo gear,on top of g/box,is used to check oil level.pull speedo cable out,youll c the oil level marks
Posted on Jul 01, 2010
Testimonial: "yes we have found that but it is not going in and we have been told of another place wich we will find out today thanks mate"
Would like to know where the top up plug for my gear oil is and if there is a dip stick manual proton savvy bt 2006
Manual Transmissions don't have dip sticks.
2. Manual gearboxes have a drain and filler plug. The filler plug is usually found in an accessible position on one side of the gearbox which has to be accessed from under the vehicle.
To top up the gearbox the car has to be perfectly level so if you need to add oil to the gearbox you ideally need to get the car up on a garage hoist/lift so you can both access the filler plug easily, remove it and pump in the fresh gear oil. The usual correct oil level on these gearboxes is level with the bottom section of the filler plug opening in the gearbox. However you should check with the proton service staff on the correct procedure for topping up the manual gearbox in your car.
Mar 20, 2016 | Proton Cars & Trucks
Where is filler plug on RT-5 rototiller gear box
I will research this. This is a Craftsman rototiller, correct?
Mar 09, 2016 | Cars & Trucks
Daewoo Nubira 98 manual gearbox
oil filler plug on the manual gearbox usually are located on iether side of the gearbox with a square or hexagonal head plug or bolt. Some are Allen head drive.
Jan 05, 2014 | Cars & Trucks
MY ROTOTILLER RUNS AND DRIVES BUT THE TINES WONT TURN
Make sure that the clutch doges as I call them are engaging properly. Also check rear tine gearbox for striped gears or sheared keys. To check some of these things it may be necessary to remove rear tine gearbox by removing the 4 bolts that hold it on to the main transmission. Hope this helps.
Sep 17, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
Apr 20, 2010 | Mtd Products Yard Machines 158CC Tiller
WHERE IS THE FILLER PLUG ON THE GEARBOX ON A 1998 PASSAT TDI PLEASE
Just checking.... it is a manual gearbox?
You may need a special tool for the drain plug and a 17mm allen key for the filler (some use the special drain tool for the filler as well)
The drain plug is located under the diff housing.
The filler plug is located on the left (nearside) off the gearbox (look to the left of the hole and you can see the 17mm hex filler bung).
Check you can undo the filler bung, then drain the gearbox oil.
Refit drain bung and fill gearbox through filler/level ********* until gearbox oil is up to the level of the filler bung.
Refit, test drive, check for leaks and retest level again when cold.
Cheers,
"If this has helped you in any way, please rate this solution" :-)
Jan 27, 2010 | 1998 Volkswagen Passat
TrueValue Rototiller - Engine Model #135202 - Carburator Trouble
Lower the flot bowl and check to nmake sure the float isn't shut close.
Jun 08, 2009 | Mtd Products Yard Machines 158CC Tiller
Need manual for mtd 5 horse rear tine tiller model 135202 need to know how to change chain
Feb 27, 2009 | Mtd Bronco Rear Tine Tiller
Need manual for roto-tiller model#135202 made by MTD
I don't have a manual and I need to know what size belt to purchase. Any help would be nice.
Feb 19, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
