I needed the information to know about concrete drive way replacement. what should I know when the contractor comes to give estimate?
    Master:
  • 347 Answers
First off you need to make certain that he is going to jackhammer the old driveway and remove it from your property. I guess before that, be sure to get a reputable contractor to do it. Check with BBB if you would like to.. Then jackhammer and remove. Be certain that they are replacing the driveway with the proper thickness. I believe it is 4". They will lay down 4"x 4" wire sitting on little blocks called "adobe" blocks to suspend the wire off of the bottom.Be certain that they put crack reliefs in when they are finishing concrete. Those are the indentations that they put in due to the expansion and contraction of the concrete so it will crack in the indentations instead of on the slab. Be certain that they form up the driveway before the wire. They put 18 or 24" stakes in the ground and then nail the wood formers to the stakes. This is what hold the concrete in. They will pour it in one day then trowel it, install the expansion reliefs and then they will take a soft hair 24" pushbroom and give it a light brush finish. All of the edges will be troweled and rolled over nicely. Be certain that he doesn't over order on concrete. Basically it is length x width x depth 27 cu ft. = 1 cu. yard. There will be a small portion over to allow for any problems. This is normal. The next day they will come back, pull the forms and your good to go. Be sure to get 3 estimates. Good Luck!
Posted on Apr 21, 2017
3 Suggested Answers
Cheetah Tech
  • 27 Answers
SOURCE: My HTC wildfire dropped on concrete today. The
You will have to replace the digitizer. Lucky for you you do not have to change the LCD from what you are saying. A digitizer for your phone is $10-$16 on Ebay. I will post links to videos on how to do it yourself. I charge $35 so I don't think you should pay more then $40 - $45 max anywhere else.
http://www.ebay.com/itm/NEW-Touch-Screen-Digitizer-HTC-wildfire-A3333-G8-/330515655249?pt=LH_DefaultDomain_0&hash=item4cf444aa51#ht_483wt_1210
http://www.youtube.com/watch?v=edemmCIW6no
http://www.youtube.com/watch?v=uB-EM2xJZAU
Posted on Aug 22, 2011
  • 1833 Answers
SOURCE: Looking for National Electrical Contractors
You can get all kind of labour extimating manuals here: http://en.gzshitong.com/au/neca%20labor%20estimating%20manual-pdf.html.After clicking this link you will be forwarded to a page contains manual. Youneed to scroll and select the required manual for download. For MECAestimating manual you can visit: http://personnellement.net/mechanical-labor-estimating-guide-pdf-1.html,and http://www.bitlib.net/ebook/mcaa+estimating+manual/. Hope this will help you. Good Luck.
Posted on Aug 27, 2011
I have a driveway that is 19 feet wide and about 100 feet long which I want to pour concrete on but i dont know how many yards that would be needed.
Need to know how deep the concrete will be. Any concrete supplier can give this information, it is free and it is exact.
Sep 30, 2016 | Building Materials
How many cubic meters of concrete will it take to pour a garage fool 336 sq feet 6 inches deep
Figure 1 90 lb. bag per square ft., 6" deep.
Don't forget sand to grade and rebar to reinforce.
You probably won't find enough guys to mix all that concrete, so you'd really be better off hiring a concrete truck.
Tip: It's best to over estimate a little so you won't be caught short.
Mar 01, 2015 | Building Materials
Repair concrete floor, large cracks in flooring
install backer rod into cracks that are more than an 1/8 and use concrete sealer (in the caulking section of your local hardware store). The backer rod is used to reduce the amount of sealer you have to use to bridge the larger gaps in the cracks.
Nov 05, 2013 | Mozilla Firefox
I painted a section of my garage floor with a cup of paint 1/4c oil base acrylic mixed with 3/4 c water base latex...will it ever dry thoroughly? it is drying slowly and is really sticky. will I just have...
did you ever try to mix water with oil? what was the result? are you sure that you can cross the street without adult holding your hand?
unfortunately you need to remove all that paint, just drop few shovels of fine sand over, and scrape it... sand will adhere to the tp surface of the pain and will allow you to scrape it. after you scrape it off, use any degreaser or similar product to wash reminder off, leave it for few weeks to dry through and then in small patch try if it would accept latex pain, roll it very, very thinly and leave overnight, if it is dry (solid dry) after 24hrs and do not peel off, you can then use this paint on the rest of your garage floor.
now, i would advice strongly against painting garage floor with any paint except concrete paint (they are usually water based with strongly alcalic ph), and after that use concrete seal. this should give you long lasting surface, sealed from oils, dust, water and whatever contaminant you can imagine in the garage.
Sep 12, 2013 | Sherwin-Williams Best Look Latex Garage...
My apprentice used grout, intead of thinset to bond 250 sq ft of quarry tile to concrete. Is there a away to fix it? without pulling all the tile?
Grout is a non-adhesive concrete material that is made with sand and cement, with colorants added.
Grout will not adhere tile to any surface
The good news (if that's possible) is that the tile should be fairly easy to remove, and the grout will be fairly easy to scrape off the floor. Break one tile out of the way, and see if the others can be pried up easily.
Looks like you have to start over, sorry for that.
I was a contractor for 30 years >>> we laid tile for about 2 years and then shifted to other trades >>> I know from experience that the big disasters become great stories a few years later >> every contractor has those stories.
Let us know how it comes out.
Oct 19, 2010 | Q.E.P. Co., Inc. Qep 60024 24"...
Not freezing
Hmm, the description, "not freezing," without much more, puts us at a disadvantage of figuring out what's specifically causing your refrigerator not to freeze.
Without much more, I can only guess that there's not enough refrigerant, and you'll need to recharged the refrigerator with refrigerant to get it to properly freeze again.
Unfortunately, if you need a recharge, you'll need to hire a licensed appliance technician/service contractor because they are the only ones authorized under federal law to purchase such refrigerant; on the other hand, you'll probably still need this technician/service contractor even if it's not the refrigerant that's the problem because the problem you seem to be having with your refrigerator requires specialized repair services that only a technician/service contractor can provide, I believe.
So, get free estimates from local appliance service contractors/technicians in your area.
Hmm, for your convenience, here is a handyman site that I came across, which has a section dedicated to appliances (like your refrigerator), where you'll find a text-link ad that offers up to four (4) Free Estimates from such local appliance contractors in your area (scroll down a bit and it's the text-link towards the middle of the page):
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone.htm
Click on the "Find Appliance Contractors...Get Up to 4 Quotes Free" text link. Guessing on here is not as productive as getting a quote upon which you can rely. Trust me, from general experience, you'll be glad that you got concrete evaluations-estimates from appliance repair technicians/constractors who have been able to see your refrigerator in person to properly diagnose the cause of its problem to freeze.
Aug 18, 2009 | Refrigerators
2 separate noices my ac unit is making
If your AC is making that kind of noise-racket, your AC is problem experiencing a loose part that needs to be re-tightened.
If it's specifically making a "rattling sound," like this great, handy article of a handyman site says, then it is likely your AC fan that's loose:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Making_Rattling_Sound.htm
In either instance, your best bet is to contact an experienced AC technician/contractor, as the making of noise is a sign of serious problem that must be fixed right away, unless you would like to experience almost certain irreparable damage to your AC in my opinion--when sounds are made that's because two or more parts are coming into conflict with each other, causing friction, and thus damage, to occur.
Get free estimates from local AC/HVAC contractors in your area who could be in the position to fix it for you (or whom you can rely on to get as much infromation as possible during the free-estimate consultation so as to apply the information for your own use). The rule of thumb is to get at least three estimates.
For your convenience, here is a handyman site that I came across, which has a section dedicated to air conditioning, where you'll find a text-link ad that offers up to Four (4) Free Estimates from such local contractors in your area (scroll down a bit and it's the text-link towards the middle of the page):
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning.htm
Click on the "A/C Contractors" text link. Good luck!
Aug 07, 2009 | Heating & Cooling
Fan does not run motor just hums
The humming of the motor may mean either that the motor is in need of some oiling (as may be applicable,some A/C's do not include this option) or the motor is just about dead and in need of replacement. Your best and most logical action to take would be to get free estimates from local AC/HVAC contractors in your area who could iin the position to fix it for you (or whom you can rely on to get as much infromation as possible during the free-estimate consultation so as to apply the information for your own use). The rule of thumb is to get at least three estimates.
Click on the "A/C Contractors" text link. Again, guessing on here is not as productive as getting a quote on the basis of a professional diagnosis from an expert upon which you can rely.
Aug 01, 2009 | Dometic Heating & Cooling
Hi, recently had a concreter disconnect my airconditioner while pouring a concrete slab. While doing this they let all the refrigerant escape. How/ who can replace this ?
Do not know where you are located, but these people should have never tried to disconnect the unit. Most states require the a person working on a HVAC unit be licensed and the EPA requires that anyone working with freon also be licensed. Venting freon to the atmosphere is a big time no no and subject to a very large fine. I would require this contractor to hire at their expense, a licensed a/c contractor and have them pay for it since they caused the problem. Freon is getting to be very expensive
May 14, 2008 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
