Question about Asko Dryers
Where are fuses on T731 asko dryer - Asko Dryers
SOURCE: asko T731 sensor suuts off the dryer prematurely
you need chek are clean folow:
1-line chute assembly.
2-housing blower.
3- pipe duct .
Posted on Oct 06, 2009
Macmarkus
  • 2605 Answers
SOURCE: What may be the cause of excessive vibration in my
One of the most common causes of what you`re describing on an Asko dryer is lint build up or static sheets getting into and on the blower wheel or the blower wheel has been busted some how. To check you`ll need to remove the lower panel so first things first...**Unplug the unit from the source or shut off the power at the breaker panel**
With the power now off, remove the 2 philips (star) or torx head screws at the bottom on either side of the panel. Once that is removed you`ll see a white plastic housing which is the vent/exhaust duct.
On this duct there is a small round cover to the left which provides access to the blower, but you may need to remove a sensor/thermistor held in place (and can be hidden in fact) with black puddy, so you`ll need to observe and handle it carefully. The small round cover will be held in place with clips molded into the plastic, a small flat/spaded screw driver will be required to remove the cover.
Once the cover is removed you`ll know almost immediately if the blower is full of lint (or anything else) and causing an unbalanced or excessive vibrating scenario.
Also check the blower nut/fastener to insure it hasn`t come loose or the blower shaft isn`t cracked or become rounded because it should be in the shape of a D where it slides onto the motor shaft.
That is the most common occurrence with the Asko dryer`s when it comes to vibrating. It can manifest from any number of thing`s though really, such as...worn drum rollers or roller shaft`s. Worn rear drum bearing or belt, and even belt tensioner (idler pulley).
I`ve just explained the likeliest cause with the blower wheel, so try that and let me know how it goes.
Hope that help`s you out. Good luck.
macmarkus :)
Posted on Nov 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: Asko T731 Electric Dryer - where are the fuses on
Welcome to Fixya.
Before starting...
**Turn off your breaker at the home service panel, it should be a 30amp switch or unplug it from the wall...safety first**
The fuses are at the back located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown.
You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, reliableparts.ca etc.
Asko part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Posted on Aug 05, 2010
SOURCE: ASKO T731 Dryer - Air is not warming up.
same thing has happened to me...please help
Posted on Sep 04, 2010
FaceTheFacts
  • 245 Answers
SOURCE: installed a new automatic reset thermostat unit and asko t731 dryer still shuts off before finished
You probably have a clogged exhaust vent.
Posted on Feb 15, 2012
Asko T731 Dryer rollers
http://www.askona.com/customer-care/resources/manuals
Sometimes there are spring clips that require a bit of prying before they pop free. Contact mfr for a parts diagram, that will show all of the parts and how they go together
Jan 06, 2014 | Asko T731 Electric Dryer
No led light how do you check fuses?
Unless im mistaken they are in the back and cover needs to come off, see this picture.
Jul 26, 2008 | Asko T731 Electric Dryer
How do i replace the belt on my asko t731
open up the back panel it is usually right ther and easy to do
Sep 07, 2011 | Asko T731 Electric Dryer
No light display
evidently. there is/are fuses on the back of the dryer, I am assuming one of those may be blown. Here is a manual I found, it does not have a wiring schematic on it, so I am assuming that Asko is the same as any other manufacture, meaning they put the schematic in the top left hand corner of the control panel on there dryers. Should be 6 screws. I hope this helps Tim:
http://dl.owneriq.net/e/e7d9f38b-5a0e-6344-6949-46091be9e970.pdf
Dec 25, 2010 | Asko T731 Electric Dryer
Asko T731 Electric Dryer - where are the fuses on the back of the dryer?
Welcome to Fixya.
Before starting...
macmarkus :)
Aug 05, 2010 | Asko T731 Electric Dryer
Dec 05, 2009 | Asko T731 Electric Dryer
Asko T731 sensor suuts off the dryer prematurely
2-housing blower.
3- pipe duct .
Oct 05, 2009 | Asko T731 Electric Dryer
Dryers Logo
64 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
