Question about Cell Phones
How do I turn the phone on. I inserted the battery but its dark . Should It be connected since the battery is in?
  • 3 Answers
Hold the power swich for 3 seconds or more
Posted on May 17, 2017
Charge the battery 1st
Posted on May 06, 2017
    Problem Solver:
  • 6 Answers
You usually have to hold down one of the buttons for 3 seconds. Some phones have it on the side and some have you hold down the disconnect call button. You should be able to search for the manual online if you don't have one. Good luck.
Posted on May 05, 2017
My LG Motion won't turn back on.
Did you tried to check your battery connections ? If not, remove your battery and clean the battery connections and then re-insert it. If the problem is still there, try a hard reset.
Feb 15, 2014 | LG Motion 4G MetroPCS
Can't get Nexus 7to turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 01, 2012 | Cell Phones
My zte wont turn on all the way
5.Wait 10 seconds.
Step
Thanks
Nov 02, 2012 | ZTE Warp
I have a Shift 3 lcd touch panel phone with 12 digit calculator.I cannot find the manual for this phone.I can receive calls but cannot call out.A manual would be helpful Thanks
  • Check your phone to make sure it is set up properly. Open the back of the phone by pressing your fingertip on the small lever that opens the battery area. The battery cover will come off in your hand. Insert three "AAA" batteries into the back of the phone so you can use the night light feature. Replace the battery cover by sliding it into the battery area and clicking it into place with your fingers. Connect the phone to the telephone phone jack by connecting one end of the wire to the phone and another end to the wall jack. Connect the handset to the phone by inserting the end of one end of the curly phone wire to the handset and the other end into the side of the phone. Listen to the dial tone by pressing the speakerphone or picking up the handset to make sure your Innovage LCD touch panel phone is connected.
  • 2
    Review calls you missed. Use the up and down arrows on the Innovage LCD touch panel phone to view the caller ID phone numbers.
  • 3
    Use the night light to view the Innovage LCD touch panel in the dark. Slide the switch on the front of the panel to turn the night light function on. Slide the switch to the off position to turn the night life off.
  • 4
    Adjust the volume on your speaker by selecting the speaker loudness that you want. Press the hands free button once and press the "Delete" button. Choose a loudness from one to four.
  • 5
    Press the hold button on the front of your Innovage LCD touch panel phone. This will activate the hold function when you are on a call and it will allow music to play while someone is on hold. The hold music is built in to the phone and will automatically play when you press hold.
  • 6
    Save a phone number as a VIP number on your Innovage LCD touch panel phone. Press set and save when an important number comes onto your caller identification. This makes it harder to delete the phone number by accident.
  • Read more: Innovage LCD Touch Panel Phone Instructions ' eHow.com http://www.ehow.com/how_7256783_innovage-touch-panel-phone-instructions.html#ixzz1eMIaaXLV
    Sep 23, 2011 | Innovage Speaker/Caller ID* LCD Touch...
    Wont charge tell me to insert sony battery
    If Your battery wont charge instead it is requesting for You to enter a sony battery, then there is a problem somewhere that need to be checked. It is either the battery is bad and require You to replace it or the charger is not working fine or probably the phones connection port is bad. You need to run a test on the 3 before you can tell which is the problem. First run a test on the battery. To test the battery please follow the steps below:
    1. Turn off Your phone,
    2. Remove the battery,
    3. Insert it in another phone,
    4. Turn it on to see if it will ask you to insert a sony battery, if it does then it means the battery is bad and need to be replaced, but if it does not, then it means it is You phone that is not recognizing the battery,
    To test the phone,
    1. Insert in another battery into Your phone,
    2. Power it on,
    3. Check if it will request for You to enter a sony battery, if it does, then it means the phone is faulty and the connection port is bad, but if it accepts the battery, then it means the phone is alright.
    Finally, test the charger,
    1. Try to use it on another phone to see if it will charge,
    2. if it charges, then it means the charger is alright, but if it does not charge, then it means the phone is alright,
    That way after carrying out the tests, you must have detected the problem and solved the problem.
    Hope this helped. Thank You for using FixYa!!!
    Jan 17, 2011 | Sony Ericsson Walkman® W995 Cell Phone
    Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
    Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
    Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
    After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
    Take care.
    Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
    I have a similar problem.
    Actually it sounds like the phone is merely off. Perhaps the battery actually died. If so and then the phone is off. When you plug in the phone with while it is off it will show the logo then it will say please wait and the the battery icon and say charging. If the phone is charged it goes dark.
    Just hold down the "end call" key for a minute and see.
    This actually happened to me once. I thought my phone was broken. Just as I was about to call AT&T I decided to try turning it off which is done the same way as you turn it on. Imagine my surprise when it started right up!!!
    Aug 10, 2009 | LG Vu CU920 Cellular Phone
    Lg vue indicates on screen emergency download
    pop out the battery. Connect charger to phone. press the power button. screen will read " insert battery". Insert battery. After the screen reads "charging" , press power button. If you turn the phone off, you will have to repeat these same steps.
    Dec 20, 2008 | LG Vu CU920 Cellular Phone
    Can't see a thing on screen
    hi sir
    please remove the battery and memory card.. and after inserting the battery first for saffer side go to tools>settings>phone> restore factory setting . after restart insert memory card it work,s sir..
    if doesn.t work mite memory card may be corrupted..
    Sep 01, 2008 | Nokia N95 Cellular Phone
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
