Question about Aiwa HT-DV90 System
Hi i have just purchased a second hand ht-dv90,the problem is it will only play one dvd film that i have and will not play any of the others ,any ideas on what the problem is.i dont fancy watching the same film over and over again , cheers
    Scholar:
  • 113 Answers
Hi, sounds like a zone issue. Check the zone on the one works and I'm sure you will find it different to the others. Not sure if there is a slution there as will have to change the zoning on it.
Regards
Posted on Jul 25, 2009
My aiwa dvd player HT-DV90 won`t stay turned, in the screen shows PROTECT and turns off ...
Check the speakers one by one, maybe one of them are damaged and make the device going on protection
Aug 26, 2011 | Aiwa HT-DV90 System
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Aiwa ht-dv90
Not good protection is a special circuit in side the machine.. You will need to get the machine repaired at a service center. You circuit board has over loaded.
Oct 09, 2009 | Aiwa HT-DV90 System
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
Aiwa HT DV 90
Here is a link to the Aiwa HTDV90 Service Manual.
Apr 02, 2008 | Televison & Video
Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
My New DVD Movie Can't Read
Some pc DVD players will only play films from a certain region. It could also be the video codecs? Search for the all codec packs on the net as sometimes a film wont play unless its got the right codec. Also some companies dont like people to play films on their computer as they can be ripped to hard drive etc. Three answers that could the the cause of your problems, sorry i coudlan't be more help :-(
Apr 18, 2007 | Lite On DVD+/-RW LITEON SOHW-1673S BLK RT...
Samsung HT-P38 won't play DVDs but plays CDs just fine
I called Samsung. They told me how to do a software reset and solve the problem
1. Take out all CDS.
2. Turn off and then on.
3. HOld down stop for 5 - seconds.
Problem Solved!
Apr 11, 2007 | Samsung HT-P38 System
Aiwa HT-DV90 System Logo
164 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
