Question about Exercise & Fitness
Can the walking belt dry out? We bought the 995 in 2003. It's gotten very light use, but we're noticing grainy or powdery residue each time we use it. Could it be the walking belt drying out?
SOURCE: After a wash the dishes are have a grainy residue on them
I had a similar problem, found that I took it all apart cleaned all the filters and ran clr or kitchen magic in it , it helped. but also found that the top arm wasn't spinning. So I took the bottom piece off with some kind of star end like a screwdriver, and the check ball was stuck. I had a time without soft water and I think the gonk made my dishwashers gunky. All is fixed now. Le t me know if this helps
Posted on Jul 26, 2008
  • 677 Answers
SOURCE: Dishes not completely drying and white powder residue left.
the problem is not the dishwasher but the water that actually is going into it. the white, powder substance is because of hard water. there is a affordable product out there called the dishwasher filtration system. it will filter the water going into your dishwasher and solve the problem once and for all!!! it is affordable and easy to install. www.dishwasherfilter.com
Posted on Feb 09, 2009
  • 16 Answers
SOURCE: mAYTAG NEPTUNE dryer takes long time to dry, notice water coming
your vent is very very cloged you need to take off vent hose and clean lint out of dryer.(do not use until you do.
Posted on Jun 27, 2009
heatman101
  • 43501 Answers
SOURCE: Pots, pans, dishes not coming clean, white residue left?
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Jun 22, 2010
  • 311 Answers
SOURCE: The dishwasher is not washing.
Either it is not filling up enough or the wash pump is not working.
Posted on Sep 23, 2010
Proform 345s stripes on the walking belt. Powdery residue on the floor below the belt. Everything functions normally, and the belt is properly aligned.
1) this a normal problem. However you must know that you must LUBE the deck belt every 5hours aprox, in according with the use.
2) You must check the tension in deck belt aprox 3- 4"High aprox from the middle.
God bless you
Nov 14, 2012 | Proform Crosswalk 345s Treadmill Walking...
I'm having white powdery residue left on my dishes - most noticable on the plastic cooking/stirring spoons and spatulas and on my stainless pots and lids. Am wondering if it's the detergent - is there a...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Aug 17, 2010 | Miele 24 in. G680 Built-in Dishwasher
Dishes have a powdery residue
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
NOTE(((excessive calcium build up inside the dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
Jul 30, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
I have a GE front load washer model # whdvh626fww. it keeps making alot of noise when in the spin cycle and the belt keeps coming off. at first I thougt it was out of balance but that was not it . when I...
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Jul 19, 2008 | GE Washing Machines
Putting my fdw60 aquarius dishwasher back together
check that the place where u put the salt in is screwed in tightley, then, i find giving the dishes a hand wash and they come up clean , ti will work fine, because if you notic, take a glass with white powdery residue out of the dishwasher and rinse it under water, and the residue is still there, so they need a good scrub and after that , they can be washed as normal!
Jul 03, 2008 | Hotpoint 24 in. FDW60 Free-standing...
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
