Question about Sport & Outdoor - Others
I don't know how to get generator motor off of Briggs&Stratton 10H.P.engine to get piston out to change rings.Can anyone tell me how to seperate generator motor from engine.
    President:
  • 1,129 Answers
You must have a 6 - 8 inch three jaw flywheel puller it is fairly difficult to do so have some patience after removing the center nut you must adjust the center shaft on puller to the corect distance on the shaft the nut just came off while positioning the three hooks around the outer ring of the flywheel, they must contact the bottom lip of the flywheel at the same time the center thresded shaft is turned in so you can turn the center shaft nut and provide positive pulling force on the flywheel after you have attained the set up of the puller by hand tighten the center puller threaded shaft to the point where it starts to be hard to turn then while holdind the flywheel by wedging a large screwdriver into the outer ring gear teeth of flywheel turn fly wheel puller center shaft with the appropriate size wrench a half turn the hit the shaft with a hammer twice turn the shaft a 1/4 turn then hit agian etc. until the flywheel pops up and pull off.
Posted on Jul 24, 2009
How to remove piston from 17hp Briggs & Stratton mower engine?
You take the head off, remove the crank case cover, take the bolt off the piston journal on the crank shaft, push the piston out of the top of the engine. To get it back in you are going to need a ring compressor and should use plasti-guage to check clearance on the crank
Oct 13, 2015 | Briggs & Stratton Measuring Tools &...
Storm responder
if the piston rings have snapped. as they can do. it can lock the piston in place. and you will need to bore out a piston bore and put in a sleeve and new piston. worst possible thing is the crank has snapped. other possible is the generator motor has seized up making it so the engine will not move.
Jan 23, 2014 | Briggs Stratton H7159 & Stratton® 5500,...
Oil and gas blowing back thru crank case vent
could be either bad rings or a hole in the piston these are thethe most probable cause of GAS and oil coming out the vent
the motor needs to be torn down to repair it could of been caused by a valve hitting the piston but won't know until torn down
Apr 21, 2013 | Briggs & Stratton Briggs Stratton Intek V...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
Jun 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
