Question about Kitchen Ranges
How do i remove the plastic lamp cover on a Rotec EUROMACH range hood?I fear I may crack the plastic cover.
    Top Expert:
  • Kitchen Ranges Master
  • 45,141 Answers
Probably squeezes in to release tabs.
Posted on Apr 22, 2017
Can I get filters for rotec range hood.....???
we have no idea here on FIXYA try the manufacturer .
Feb 06, 2017 | Kitchen Ranges
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
How do i pull out the bulb for my pt61dl34?
Remove the four screws that hold the cover over the lamp compartment and take the cover off. There is a black plastic vent hood in the opening, At the bottom of the front rim of the hood there is a little tab. While pressing the tab gently pull the vent hood out of the TV. If you look up in the opening you will see the lamp housing. The There is 1 screw ont the left side frame, Turn the screw until it is loose. It doesn't have to (and probably won't) come all of the way out because its part of the lamp housing assembly. You'll see a wire that runs across the top, down the right side and under the housing. Grab the right side of the wire, its actually a handle to pull the lamp from the TV.
Feb 18, 2011 | Akai PT61DL34 Television
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
Venmar stove hood, plastic cover for light is broken
Need plastic cover on Venmar vent Hood, which measures 3 1/2 inches by 18 inches with 2 tabs.
Sep 06, 2009 | Venmar Kitchen Ranges
My 2007 Sante Fe fog lamp bulb went out and I wasn't able to
Step:
1. Turn tires away from vehicle
2. There is a plastic covering in front of the wheel that usually goes around the wheel well. There are plastic thumb pins on the outer edges of this plastic covering. Remove the thumb pins and this plastic piece will come off.
3. Behind this you will find access to your fog lights.
4. Remove/Replace just like an ordinary head light.
Jul 17, 2009 | Hyundai Santa Fe Cars & Trucks
Dont know how to take lightbulbs out of cookerhood
How do I change light bulb in my windcrest hood and what type does it take?
Mar 09, 2009 | Kitchen Ranges
2002 trailblazer
All you have to do is find the "round rubber cover" on the back of the headlamp, pry it out with a flathead screwdriver and the lamp is right there.
To remove the headlamp assembly on a Trailblazer, remove the plastic panel that covers the hood latch assembly.
Take the cover for the air filter in order to get to the low beam cover.
Take the 3 screws out of the air filter cover and remove. You will then be able to get to the back of the low beam lamp. The high beam is reachable without this hassle.
Oct 07, 2008 | 2002 Chevrolet TrailBlazer
Water dispenser is spraying water from behind the paddle instead of the opening
the grill will pop off with just a little bit of pressure. the grill will not break. once you remove the cover there is a conncetor that most likely has come loose..
Dec 04, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
