DirecTV RC65 Remote Controlwww.directv.com/learn/pdf/Remote_Controls/DIRECTVRC65forWeb.pdf
you wont get many functions on any non genuine remote
on /off sound and a few up down and side buttons at best
SOURCE: Sentry really big universal remote
Request Information
by sooky, posted on Jan 12, 2008
Does anyone know the codes for a Vizio LCD TV?
The code to use is LG 1292...these other two have worked for others as well...0178 or 0030. good luck
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: can't get DirectTV rc65 remote to program the tv
Cant connect RC65 to Samsung 46" LED TV or Panasonic Blue Ray. Have followed instructions and tried all codes. no luck :(
TV model is: UN46B6000
Blue Ray is: BDP-120
TXS
SOURCE: Our direct tv remote won't work with this tv..
For the Apex 4088, choose Astar brand. Enter code: 11531.
If this doesn't work, 11548 or 11738
Good Luck!
