I purchased a fire stick and I'm trying to hook it is to my tv I'm getting nothing should I still have my cable wire in my tv I have tried both ways and get nothin
    New Friend:
Yes you can continue to use your cable. Firestick is connected to the HDMI port. You must have your tv source on HDMI to configure Firestick. Lastly, you must have a good wireless internet signal to setup Firestick.
Posted on May 09, 2017
CremeStout
  • 115 Answers
SOURCE: No TV audio coming from Sony DAV-HDX500.
If you are trying to make your TV audio come out your Sony system, you didn't say what the input to your TV was from (ex;Cable TV,Sat TV).
Sometimes it is easier to take the external (cable or Sat) out puts and feed the video into the TV but the red white into the AMP (TV input)then select TV on your AMP to hear TV.
Also some tv's need to make a speaker choice! go to Set up and change the speaker set up for the TV, you may have to tell the TV no speakers to create out put to Amp from the REd White TV out put.
Posted on Nov 29, 2007
  • 1030 Answers
SOURCE: Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
Posted on May 02, 2008
SOURCE: Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Posted on May 04, 2009
  • 9 Answers
SOURCE: hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Posted on May 15, 2009
budmrtn
  • 11361 Answers
SOURCE: trying to hook up laptop with haier tv using vga
Dod you use HOTKEYS on the laptop to tell it to send the signal the VGA outlet of the laptop? The hotkeys function can be set to turn off the laptop screen and only have external monitor to be the only display or it can be set to have both of them on.
Posted on Nov 03, 2009
Setting up fireTV stick. It's plugged in to TV and power.ts Tried all inputs on TV. None worked. What am I doing wrong???
not sure if this link will help you out.
1. The easy way (5 mins)
  1. Plug your Amazon Fire TV Stick into your TV and plug the USB power cable into a spare USB port or use the power adapter.
  2. Go to Settings. ...
  3. Go back to the homescreen and install an app called Downloader - this will be listed under the Popular Fire TV apps section.
More items...
How to install Kodi on the Amazon Fire TV Stick: 3 BEST ways to ...
how to set fireTV stick Google Search
Oct 28, 2017 | Televison & Video
I need to set up an account for fire stick please.
FIXYA has nothing to do with FIRESTICKS
Oct 01, 2017 | Televison & Video
Hi, I purchased a firetvstick but it does not respond after plugged into my smart tv. help
Check list:
1) Do you have your fire stick powered?
Connected via usb cable to a power adapter
plugged into a power strip that has the power on,
power switch is off....so on.
2) Do you have your TV input set to the correct HDMI input?
Depending on the model you may have 2 to 4 HDMI inputs.
This is the most common error.
Please make sure the input is set to the correct input
of where your fire stick is plugged in to.
3) If you have power and the input in your TV is set.
And you still have nothing.
Then your firestick might be defective.
4) If it is working, read the instructions carefully.
connect your fire stick to your wi fi and register your fire stick.
Then enjoy!!
Aug 30, 2016 | Amazon Fire TV Stick
Just hooked up the streaming stick to HDMI to the TV. nothing is showing up, What do I do now?
Sounds like you have a bad connection on either your roku stick or your HDMI PORT.Does you ROKU stick show a white light if not check power cable or electrical plug.
Try wiggling ROKU stick just a hair or push it in and out until you get a signal..A purple screen with the words ROKU should show up on TV.If you have a bad port on TV it would have to be replaced but this is rare,if you have a second port on tv try that.Have you tried your ROKU stick on another tv?Does your streaming stick go in vertically or horizontally,if it goes in vertically it may be pressing against side of tv prohibiting a good connection.You could try a HDMI cable, plug the HDMI cable into tv and put ROKU in other side of cable.There is also a restart button on ROKU stick push it and it will start blinking,if it doesn't light up you may have a defective ROKU stick.
Feb 25, 2016 | Roku Streaming Stick HDMI Version
How do I register my new Fire Stick received as a gift ?
Register or Deregister Your Amazon Fire TV - Amazon.com
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.New Year New You. All .... Register or Deregister Your Amazon Fire TV Device ... If you purchased your Amazon Fire TV device from another retailer or received it as agift, follow the on-screen ... From the Home screen, select Settings > My Account. ...Differences between Amazon Fire TV and Fire TV Stick ยท Amazon Fire TV ...
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five ... If you received an Amazon Fire TV box or stick in your gift haul, .... Got an amazon fire tv stick and cannot access the home screen to register with my ...
Jan 11, 2016 | Televison & Video
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
How to hook up my dvd player to my cable box
Richard,
I would have to guess that you are hooking up a DVD recorder?
If you are then you take the video and audio cables out of the cable box and hook them in to the DVD R input plugs. The output wires go to the TV video/ audio in. Its just like hooking up a VCR.
Now if you are trying to hook the DVD player up to watch movies then you have to hook up the audio/video cables up from the DVD to the back of the TV into your Video 1/2 input. If you have the Component wires you hook them up the same way.
Now if your TV only has the one set of plugs (video/audio) then goto your local Audio/Video store and pick up the A/V cables that have the "Y" or "T" plug on one end.
I hope this helps you.
Mar 27, 2008 | Philips DVP5140 DVD Player
Hooking up a sony playstation 3 with digital optical cable
Dec 27, 2007 | Onkyo HT-S790S System
Pip
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Aug 19, 2007 | RCA P52930BL 52" Rear Projection...
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
