Question about Black Office Equipment & Supplies
Correct way to insert new ribbon. black on top and red on bottom?
    Top Expert:
  • Black Master
  • 48,219 Answers
Normally black on top
Posted on Apr 21, 2017
  • 1113 Answers
SOURCE: correction ribbon
Posted on Oct 27, 2007
SOURCE: The thermostat on my electric baseboard heater has
If is 120 volt heater.The thermo can use 220 or 110 volt.The elec is only using the 110v half/side of therm.Should be ok.Does it work?OK to leave blacks unused.
Posted on Mar 16, 2010
  • 3594 Answers
SOURCE: I put in a new
On the older WW's there is a large black plastic gear on the R. side of the printer they do get tooth for tooth. try wiggling it to free it up, with the power off it should move easily.
Posted on Oct 18, 2010
  • 11800 Answers
SOURCE: Hi i recently got a
You were thinking about the buffer circuits - those can be found only on LCD screens. In a plasma the pixels are commanded directly by the Y and Z -sus boards. so if you have horizontal lines on the screen that are badly controlled then it's surely the Y-sus board's fault - it has failed and you will have to replace it.
Unfortunately finding an Y-sus replacement board for your model of tv will be very difficult - i couldn't find one online. Try searching thru auction and other sites that deal in second hand stuff, in repair shops (some of them by tv's for parts), but a repair shop of a dealer would be my best bet.
Posted on Jan 26, 2011
  • 3594 Answers
SOURCE: I have a new black and red ribbon for my Smith
Most ribbons wind to the outside of the spools. Take the ribbon off, type and watch the take up spindels to see whitch way it moves and install the ribbon that way.
Posted on Jul 15, 2011
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
Replacement ribbon for canon mp-11dx calculator
I did replace the ribbon correctly. I used a universal replacement. the black part of the ribbon in on the top and the red at the bottom but I am not able to print clearly on the tape. What would be my problem?
Sep 23, 2012 | Canon MP-11DX Calculator
I have a new black and red ribbon for my Smith Corona Silent Super typewriter. I took the old one out a long time ago. I know the red half goes on the bottom and the black on top but I am not sure which...
Jul 15, 2011 | Smith Corona Office Equipment & Supplies
I have a TA Adler-Royal 1123 PD nova printing calculator. (It is very old.) The numbers printed on the tape are very faint. Do I need a new ribbon or something else? Is there such a thing as an ink...
You need a new ribbon.
Older or much older desk top calculators used a small sized ribbon such as the old typewriters used except that the reels were about 1 inch across. Often they were divided into a red and black side.
It the calculator had all of the numbers strike the paper at the same instant, then it would use an
Here is a link to an page that sells the correct ribbon for your calculator.
Here is a picture
Hope this helps,
Best Regards,
Dec 29, 2010 | Vacuums
Need visual instructions to change ribbon
Move the blue lever on the R. side of the ribbon to the rear and lift the ribbon out unsnap the correction tape from the bottom, reattach the correction tape to the new ribbon. Insert the the two small tabs on the rear of the ribbon into the slots in the ribbon deck and snap ribbon into place. For apicture go to, click your way to publications and you will find a manual.
Oct 19, 2009 | Lexmark Wheelwriter 15 Series II...
Old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Sep 07, 2009 | Brother Office Equipment & Supplies
Replacement of correction tape
The correction tape cartridge "piggybacks" under the ribbon cartridge. Flip your black ribbon over, line up the front dges of the two ribbons and gently press down on the correction ribbon 'till the two wing tabs at the top are attached to the slots at the top of the black ribbon. Be sure to take up any slack in the ribbons BEFORE re- installing.
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
Nintendo dsl touch screen replaced, now wont turn on.
the black clip has contacts on it as well and the only way i have found to fix this is to replace the black clip
May 07, 2009 | Nintendo DS Lite Console
PRINT COLOR appears that the ribbon is on upside down..The black has to be on the top and the red on the bottom. Just switch spools and turn the ribbon over..either that or there is a spring off the ribbon platform solenoid on the right side of the printer just below where the ribbon comes off the spool. If the spring is off or broken the ribbon platform will rise too high and print in red. Remotely the solenoid (little blue thing) could be bad or out of adjustment.
Hope this helps..this is usually all it can be.
Nov 27, 2007 | Sharp EL-1750PIII Calculator
Top Black Office Equipment & Supplies Experts
Walter Dominguez
Level 1 Expert
Lawrence Oravetz
Are you a Black Office Equipment and Supply Expert? Answer questions, earn points and help others
