Question about Tablets & eReaders
Can't get my deerbrook 7 db+ tablet past start up loop. i can't get to hard reset
I have tried to get to the hard reset menu several times and can't get there please help
spshort
  • 36 Answers
SOURCE: UNABLE TO LOG ON TO SLY ELECTRONICS 7" 4GB TABLET
Hold down the power button and the volume up button after shutting it off.
You might need to flash new firmware.
Posted on Jan 15, 2014
mindreader
  • 578 Answers
SOURCE: I have a nobis Tablet.I tried to do a hard reset
guess is that the float level is not closing (need to open float bowl and clean everything inside with carb cleaner. Confirm that the float is operating (up and down) . Reassemble and try again...should be fine.
Posted on May 25, 2014
  • 16 Answers
SOURCE: This is what I received as recommendation because my Samsung tablet wonturn on and I was given the following tip: "Try to hard reset or soft reset, for this procedure search on google.com how to reset
Please specify the model number of the Samsung tablet..
Posted on Sep 16, 2014
  • 7 Answers
SOURCE: How do I get my CMP759 TABLET to stop loading? I tried resetting it several times and it turns off. When I turn it back on it will only stay in the loading stage.
I don't know much about these, but my husband uses tablets and says there might be a hard reset. Sometimes a very tiny button that is reset somewhere.
Posted on Dec 31, 2014
Testimonial: "I have already tried resetting several times but it doesn't help. Thanks anyway."
easybill99
  • 996 Answers
SOURCE: I performed a factory reset on my Maxtouuch 7" tablet & now it wont load, I've tried a hard reset but still frozen on the loading screen, please help
reflash with latest files with flashing tool
Posted on Jan 23, 2015
I am still waiting for help with my DeerBrook 7 DB+ tablet it has KitKat operating system
This may not sound like help but I do not see a real question. You should mention more about what it is or is not doing. My best suggestion is to contact the maker of this tablet.
Apr 21, 2017 | Tablets & eReaders
How to hard reset prestige eliet visual land tablet
Hard Reset To hard reset your Visual Land Tablet, you need to follow the instructions below carefully.
1. Turn off the tablet.
2. Press and Hold Volume Up and Power button at the same time.
3. Keep holding the buttons till you see the start up screen.
4. Press Volume up five times when you see the android with an exclamation to reveal the recovery menu.
5. Since touch screen doesn`t work on this mode use Volume and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Apr 01, 2017 | Tablets & eReaders
My tablet was working fine the next day I went to use it I turned on it wont go past trio@9dualcore
if other solution fails, you can do a hard reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
appears.
try it, it works and start thngz afresh
Apr 04, 2015 | Mach Speed Trio Stealth G2 Tablet -...
How do i change language back to english i have a Dragon touch
To change language:
  1. open settings
  2. scroll down to a logo which is a square with letter "A" in it.
  3. touch very top option.
  4. pick correct language from list.
Now it will be what ever you have chosen from list.
Feb 05, 2015 | IKASEFUTM Soft Silicone 7 inch Android...
I have a pro scan 7 inch internet tablet but I can't get it past the android screen. I have tried several times to restart with no luck, how do I get past it. It worked fine when I first got it but t
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Feb 05, 2018 | Tablets & eReaders
Switched on my nexus 7 and it wont go past the multicoloured x
Only thing to really do is wait for the battery to die all the way, then try the hard reset after it charges up a little bit.
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
I have a hello kitty tablet pc and have forgotton the pattern to unlock it
iglo hello kitty 7" tablet, rockchip RK2926, pcb :YH-T700RA, master reset
Tablet powered down
1.Power+VolUp while booting to enter recovery.
2.You can release buttons after you see Google on screen
2.When Stock Recovery starts you will see the Android fallen down screen
3.To bring up the Recovery menu
Power+VolUp to show recovery menu.
Must be this sequence Press/Hold Power, THEN Press/Release VolUp, release Power
4.Within menu
VolUp to move up
VolDn to move down
Power to select
Jan 16, 2013 | Tablets & eReaders
Tablets & eReaders Logo
74 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
