Take wires from the track and place directly on the motor contacts. See if it tries to move. If motor tries but won't turn, could need an oiling of the bearings or the gears have jammed.
Another question - is it DC or DCC? If you put a DC train on a DCC line it will buzz, visa versa it won't usually do anything.
If DC, then above solution will help fault find.
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
You need an ethernet connection between your PC and the CS2, a simple ethernet cable will do.. However, to actually communicate between PC and CS2 you need a program that generates the right protocol like Rocrail, Win-digipet, or Train Control.
If the wheels don't move even when you try to "slide" them with your fingers, the possible problem is with the motor brushes: with a pair of tweezers gently push the springs that hold the brushes (there is one cooper brush and a carbon brush, on the motor). Remove the brushes and replace them by new ones (available from any Marklin dealer). Notice that there are 2 brush models - for old motors and new motors (these ones use 2 carbon brushes instead). Hope this helps. Best!
Probably the springs of the inverter unit are broken or too old. If you replace them by new Marklin springs, it shoud work. Notice that they must be the correct Marklin springs: any other springd probably won't work because their tension is not the correct one. Best!
You may want to try at this site: http://www.marklin.com/tech/ It is a tech page for Marklin products. I did not dig into the page but it looked like it may have something to help you.
Good luck.
I assume you have the Treetop Tender car on the track? The treetop tender is car that makes the electrical connection between the track and the train.
1. Use a volt meter across the track. You should have about 10.5VDC on the track (anywhere on the track)
2. Even without the Loco on the track, the Treetop Tender should light up if you have power to the track. If you have power and the tender does not light. Check the brushes located between the wheels on the tender. These are the motor brushes that pick up the current from the track for the train set. Make sure they are contacting the track.
3. Add the loco to the track and plug in the large black plug from the tender to the loco. Turn on the power and press forward. The train should start rolling.
Try all the functions, bells, ho ho ho, all aboard etc ..
Add one car at a time and make sure that each one lights up before moving on to the next.
