Question about Yamaha Audio Players & Recorders
Yamaha surround sound remote control rav254 we45870 us My Mute button no longer works on my remote control. The volume button is slow to volume up or down. Do you have any suggestions on how to fix?
    Habit-Forming:
    New Friend:
  • 62 Answers
The Yamaha RAV254 WE45870 is no longer produced, but you can get a clone of the Yamaha RAV254 for $29.90 that has the MUTE, and Volume buttons already programmed to work right out of the package. Here the link to the Yamaha RAV254 WE45870 page
https://www.remotes.com/yamaha-p/yamaha-rtwe458500.htm
Posted on May 01, 2018
    Top Expert:
  • Yamaha Master
  • 79,865 Answers
Replace the remote?
Posted on Apr 21, 2017
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
Can't program comcast remote to yamaha yas-101
The only thing i was able to do was to use this link and make the remote learn the functions by following the instructions on the Yamaha web site for the sound bar to AUX. YAS 101
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/
I then used the instructions below to volume lock the aux so that i did not have to switch back and forth from cable to aux to adjust volume and change channels
Setting Global Volume Lock
Global Volume Lock will force the volume and mute keys to be controlled by one device.
  1. Press and hold the "Setup" key until a device key blinks twice.
  2. Type in the code 993. A device key should blink twice.
  3. Press and release the device key for the device you want the volume locked to.
  4. You will get two blinks if the lock is successful.
Jul 03, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Yamaha yas-101 uverse codes
I had the same problem with my U-verse s10-10 remote and a yamaha SR 300 soundbar. Here is how I got my volume control (but NOT power control) on the yamaha working:
First - always send volume control to the AUX button:
Press and hold AT&T key and OK for 1 second, release, look for 2 flashes.
Now press AUX button. The AUX button will show a long flash.
Second - Go through the manual programing steps listed in the guide for the AUX button (hold AUX and OK for 1 second, release; 2 flashes, punch in code). But instead of pressing the Power button to try to turn off your yamaha soundbar, press the volume up / down and Mute button. I think the code that worked for me was 4045 but I honestly don't remember.
The key is that you have to send the volume control to the AUX button first or it's all a wash.
Jun 26, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
I have a yamaha "htr-5630"
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume, for all intents and purposes it's not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Mar 07, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I accidentially hit a button on the remote on my Yamaha receiver, now there is no sound coming out of the speakers on the surround sound
Examine the indicators on the panel carefully. I'm sure a clue is there. Maybe a wrong source, mute, speakers off, tape or 6-channel input activated?
Select FM, tune a station, leave the volume set midway and use THAT as a troubleshooting tool. Eventually, you'll find the switch or button.
Feb 18, 2011 | Yamaha HTR-5590 Receiver
Open the case of the remote to clean contacts
This maintenance procedure will not accomplish the desired result.
Sep 27, 2017 | Audio Players & Recorders
Blinking light on volume control
i have a same problem, but on a rx-v1070, worked fine for a long time and one day i just turned it on and boom light blinking and no sound, if i crank the volume to about 80-90% i get distorted sound, i think our amps are gone, checked the fuses and they seem ok. Most likely its the amp. This unit was around $1200 back in a day. And it still produces sounds better then many recievers in stores today, too bad it has no 5.1ch surround.anybody have a solution pls let me know, for now i have a weak pioneer with 5.1 but no power.
Dec 11, 2007 | Yamaha RX-V870 Receiver
Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Sep 03, 2006 | Yamaha RX-V793
157 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
