Question about Health & Beauty
Can I use a extension lead to,charge my scooter
  • 16,841 Answers
We don't know what you mean by extension lead.
Posted on Apr 21, 2017
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
on Jun 19, 2015 | Razor E100 Electric Scooter
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
I have 18volts at the box that the battery leads go to and the consol leads go out of. the warning beeper goes off even when standing still and in neutral. i have tryed bridging the leads from battery to...
18 volts is not enough voltage to run this scooter. You have 2 batteries that should each read a max voltage of 13.5 volts each or 26 to 27 volts when fully charged and measured in series. 2 batteries that are 50% charged will read 24 volts. Your batteries are almost dead by this measuring method. Charge them up or replace them and your scooter should run. Hope this helps.
Feb 18, 2011 | Electric Mobility 4 Wheel Power Electric...
Just wondering if I can buy extra batteries and charge them without them being in the scooter and how hard is it to change out the batteries, my goal is for the kids to ride one one set while the other set...
Depends, some tabs are directly soldered to the batteries themselves so you will need a soldering iron to remove the tabs. After that, it wouldn't be too hard to remove and replace.
Keep in mind that these take 2x12volt batteries and these lead-acid type batteries may take a long time to charge depending on the current your charger is supplying.
If you plan to charge the two batteries with the stock charger, then you would have to wire the 2 batteries in series for 24volts (stock charger 24v) and for convenience you may also want to head out to your local electronics store to see if they have the female socket that the charger goes into, and possible some wire, connectors/tabs that attach to the batteries and possible some small alligator clips if required.
Nov 21, 2010 | Razor E300 Scooter
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Electric mobility Rascal 265 LE scooter won't run 24 volts dc on batteries no sound or movement
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
May 02, 2009 | Electric Mobility Mobility Electric Power...
Sterling sapphire 2 4wheel scooter
Many scooters use a special charger that will not overcharge the batteries. Your best bet is to run a long extension cord to wherever you are safely storing you scooter and use the on-board charger. Be sure to charge your batteries often, since they last a lot longer if you do not run them down too far.
Oct 27, 2008 | Health & Beauty
Health & Beauty Logo
29 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
