Question about The Office Equipment & Supplies
Husquivarna z254, 54inch cutting 0-turn, thanks
    New Friend:
Try cleaning out the air filter with air compressor check all cooling fins and radiator are clean
Posted on Apr 21, 2017
What would cause the mower to slow down and stop after 3 hrs mowing then after it cools down it moves what would cause it to do that ?
you have unseated valves the hotter it gets the less power you have until it stops to cool down need to take to shop and get vavle job about 100.00 dollars if you wait you will damage motor
Aug 29, 2014 | Husqvarna Garden
My Craftsman lawn tractor with 19 horse B & S Twin with hydrostatic transmission loses speed and power in forward and reverse as it warms up. Within 20 minutes reverse will be gone and forward mo
more than likely your low on transmission fluid. I heard alot of this pertaining to hydrostatic transmissions on yards with inclines. I would check your fluid level .
May 14, 2014 | Craftsman Garden
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
I have a Craftsman lawn tractor, model # 917.276180. After mowing for about an hour, the transmission starts to slow down and eventually stops. The tractor s/n is 03006D006025 and was purchased new from...
Hi, remove the battery and battery carrier and clean all grass and debris from the hydrostatic drive, cooling fins and fan. I'm not sure what transmission it runs but the solution applies to all. Hope this helps, regards Phil.
Aug 25, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a John Deere lawn tractor L118 42 inch cut. As I cut my lawn, initially it runs great. However, the last few passes, the mower looses forward speed and barely carwls and has no reverse, When it...
Hi, the most likely cause is the transmission over heating. Remove the battery and the cradle underneath the battery. Here you should be able to access the transmission. Clean all grass and debris from the cooling fins and check the cooling fan for damage. Hope this helps. Regards Phil.
May 03, 2011 | Garden
Speed of tractor slows when I run for more than 10 minutes. It will not climb a small incline after it gets hot. I can let it cool for a half hour, then it runs fine untill it gets hot ,and eventuall will...
you need to call a dealer and get a price to replace the transmission. perhaps you can swap yours for a rebuilt tranny. If you are at all mechanical, you can change the transmission yourself in an afternoon, so some cost could be saved on labor.
Apr 24, 2011 | John Deere 22HP VTwin 48" Riding Mower
17.5 hp 42" deck Sears tractor. Parked it in the shed after last mowing, everything was fine. Went to mow yesterday and tractor will not drive plus I have no brake....what happened? Belts are fine, gear...
If the engine is running normally and your drive belt is fine then the input to the transmission is OK you just have no power output from the transmission. Usually those transmissions give you some signs of failure such as won't go up inclines or the top speed is a bit low. What I would do is first check the linkage from the forward/reverse lever to make sure it is moving a corresponding shaft on the transmission itself. If that is good then I would check the fluid level on the transmission itself. This could well require removing it from the tractor. Often the brake pedal is connected to a small disc on the transmission. While you are checking the shifter input to the transmission, you may want to follow the brake pedal rod back and see if anything is broken or disconnected.
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My YS4500 (3 yrs old) has recently been loosing power in the hydro transmission. The engine runs great, but the drive stinks. I have to ease it into drive and as it gets going it will pick up speed, but if...
Yes, what I believe you have, is a loose drive belt. this can be due to several things,1st, the drive tensioner spring may be broken, 2nd,the drive belt tensioner pivot arm may need lube, or the belt is worn out.
You did not mention the hydro making noise(whining) if that were the case i would have you check to see if the brake were sticking.
Sep 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
46 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
