Question about Elite Health & Beauty
Hello..i am needing a go go elite traveler scooter service manuali around a 2008 year
  • 32 Answers
SOURCE: lost the main key and can't find the second key.
most keys for that type of scooter are the same, (not like a house or car key) call Pride 1-800-800-8586 for replacement or any Pride dealer can help you. Also, a paper clip can jump the ignition by placing it in their to get you around temp.
Posted on Apr 20, 2009
bunnydawg
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
  • 26 Answers
SOURCE: i have a go-go elite traveller scooter and the
if light does not work fault in wiring or connection
Posted on Apr 15, 2010
  • 14 Answers
SOURCE: we have a 11 month old elite traveler scooter. The...
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
Posted on Jul 05, 2010
gewiz
  • 1263 Answers
SOURCE: needing to replace free wheel mechanism go go elite traveler scooter
em, this is new to be , can you go into more detail of the actual problem ?
Posted on Dec 09, 2012
Tzora easy travel classic. Where can I get worm gear or gear motor?
Hello Kees,
Check with Ebay and amazon, Most of the time the maker of the scooter has you over a barrel, and you will need to order a whole new unit. Parts are not being sold from the drive maker, they are only interested in selling new units. for the price of a new scooter, many times you are able to get a used one that will be great for a parts vehicle.
Nov 12, 2015 | Tzora ELITE Elite Easy Travel Scooter
I need to re-set the potentiometer on an Easy Travel Classic scooter. Anyone have the procedure?
Hi all ,you need to do is make sure the throttle lever cross head is dead centre, got a meter ? then disconnected the throttle pot connector and measure one outside pin to centre pin , it should measure around 2.5k ( resistance)
Regards
Rob
www.gewizrepairs.co.uk
Mar 03, 2014 | Tzora ELITE Elite Easy Travel Scooter
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
My parents have a Go Go Elite traveler, 3 years old, all of a sudden it takes off and then it starts to hesitate and then takes off again. Please help. Can't find service center in CT.
sounds like a short circuit, check the wiring and connectors, maybe add some insulation tape to conectors and any cable showing the metal wire.
Aug 16, 2013 | Pride Mobility Products GoGo Elite...
I am travelling by air next week and I need to know the serial no. of my scooter. Where do I find this. I have a 4 wheel Go-Go Elite Traveller Plus Hd
hi , its located on the bottom part of the seat stem , you will need to remove the seat and battery pack to see this,
Regards
Jan 25, 2013 | Pride SC53HD GO-GO Elite Traveller Plus HD...
Can I buy new panels for a Go Go Elite mobility Scooter
Hi Tracy,
Yes, you can buy new shroud panels for this model in red, blue, and silver. Some of the panels, front, rear, side strip, and console, velcro on the chair and can be replaced by the end user. This is model SC54HD for the go go elite traveller plus HD 4 wheel scooter. For about $60 you can get the entire set of panels for a color change.
If I'm not mistaken some of these scooters come to our dealership with the extra panels already in the shipping box. This allows for a quick color change during dealer prep. Call around to several local dealers and see if they have extras available at no charge before purchasing new ones.
Jan 02, 2011 | Pride Go Go Elite Traveller Plus HD 4...
Where can I get the best price for batteries for my go-go elite traveller 17A @ 78, y.o. I have to foind the least exspensive Thanks Edward.
In my experience the cheapest batteries are not necessarily the best. The small 17 Ah batteries for this scooter should be AGM (Advanced glass mat). The less expensive batteries will last you about 6 months or more. The AGM batteries should last 1 year or more but they are more expensive. Shop around on-line and you should be able to find them locally at a good price. They are easy to replace but it requires a long #1 phillips screwdriver to get the battery box screws out. If you do it yourself or have a friend do it you will save on the labor cost which can be significant. I have seen them on-line from $34 to $179 so be sure to shop around. Hope this helps.
Nov 17, 2010 | Pride Mobility Products Go-Go Elite...
Trans/axle noise, slow to apply brakes, no available service information
This did not fix anything. However I have found that there is NO service infomation from Pride on these scooters. No shoes, nos shirt, NO SERVICE.
Aug 14, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
Top Elite Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Jeff Tilburn
Jeff Tilburn
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
