Question about Garden
Riding lawnmower will not move forward or back husqvarna. Runs great. All serviced for summer
    New Friend:
Check drive belt
Posted on May 05, 2017
  • 246 Answers
SOURCE: lawnmower stalls out
Hello:
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 11 Answers
SOURCE: Honda HTR3009 riding mower runs great but won't
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Posted on Jun 24, 2009
  • 634 Answers
SOURCE: I have Husqvarna yth2148 riding lawnmower belt
goto husq site and type in model ect and should give parts and diagram
Posted on Jul 06, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
  • 3911 Answers
SOURCE: husqvarna tractor won't go in
if you scroll through many of these posts, you will find that husqvarna make most frequently has a failed transmission. you have to replace the transmission and they are not cheap. if you can find the company which made the tranny, and the model, you can search for "new old stock" transmissions for sale cheap on eBay. the company name will be on the bottom or the top of the transmission. this being a "jelly side down " world you most likely will end up having to remove the transmission to see the top of it. there are only a handful of companies making them.
those mowers are actually made by MTD or AYP. not really a husqvarna product.
Posted on Jun 30, 2011
Husqvarna YTH20K46 lawnmower does not move forward when in drive
Check the drive belt and pulleys. Make sure the belt is tensioned when you release the brake.
Aug 25, 2014 | Husqvarna Garden
I have a Husqvarna YTH2348 that I bought from Lowe's last summer. As I was mowing today it suddenly started to vibrate excessively. I believe the problem is in the transaxle. When the brake is engaged...
There are usually one or two idler pulleys on the belt that runs from the engine to the transmission. Check those, more than likely one has gone bad. the should spin freely with the brake engaged, and the should not wobble.
Sep 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Will not move forward or back
either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Mar 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husquvarna hydrostatic mower won't move
Sounds like the belt going to the hydrostate broke. Or a key on one of the pulleys broke. The belt runs inside of the frame and is hard to see.
Jul 11, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Serviced my riding lawnmower runs great. but when I put in drive it dies out. Also when I engage blades it dies out. No problems last summer. It won,t stay running when I do these two steps
Probably the seat safety switch. If it's not activated (from your weight on the seat) the engine is killed when you put it in gear, or engage the blades. Lift up the seat and check the switch - wires on tight? switch tightly mounted? You can take the switch out and tape it in the pushed-in position to test things. If that doesn't let the mower run, the switch itself is probably bad, but it could also be a connector that knocked loose when you serviced the mower. Check wires and connectors. Good luck!
Jun 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Wont move forward or reverse-- transmission??
Oct 10, 2009 | Garden
Lawnmower will not go forward or in reverse. Brake is not engaged.
Is the lawnmower in transport mode. I know alot are underneath the back and it is a a small handle that when engaged disallows the mower to be put into gear. Let me know if this isnt the problem.
Aug 23, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine runs good and blades turn fine but the lawnmower does not move forward or reverse.
the freewheel control is in the wrong position. push in all the way for mowing. This control is located on the rear of the mower below the seat.
May 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
