Question about Sony Audio Players & Recorders
Can I parallel wire two exreternal/exterior speakers that re 8 ohms nominal to my Sony STR-DG520 receiver?
    Top Expert:
  • Sony Master
  • 79,865 Answers
Yes that would work.
Posted on Apr 21, 2017
Can you tell me model number of the speakers who compatible with my sony str-333s receiver.
HI,
Sony STR 333S have an out put power of 25W into 8 Ohms speakers. You can use any bookshelf speakers with an impedence of 8 Ohms.
Ok
Mar 06, 2012 | Audio Players & Recorders
I have a str-de750 and a str-de597 both after less than 2 years of use flashed "protected" and are rendered useless to me.I will not purchase a 3rd one unless this can be resolved.FYI since the...
Hi, It may not be a wiring problem, or a heat issue, but it should be related to what is at the other ends of the speaker wire. I, of course, don't really know what is happening with your receivers. I guessing.
My only rational guess besides the receivers having been defective is this.
So here the theory part:
An amplifier is designed to operate with a certain amount of 'LOAD" on it's speaker outputs.
It will say something, in the manual and perhaps on the back of the unit itself at the speaker terminals
"4-8 Ohms (a measure of resistance, the load itself) 4-16 Ohms, etc.
So what happens when you wire in parallel Two 8 ohm speaker systems together. You get 4 ohms.
Not a problem.
What happens if you wire four 8 ohm speakers together, you get a load of 2 Ohms. This level of resistance if very low for a receiver and it will go into a protection mode. If you were able to run it without protection, the output transistors would cook internally. The Receiver itself wouldn't necessarily get hot. But that would happen.
If you put four 4 ohm speakers together. The amplifier would see 1 ohm resistance. That is almost a short circuit.
So if you happen to be running multiple speakers together. Check this point out.
Hope this helps,
Best,
Mark
Jan 19, 2011 | Sony STR-DE597 Receiver
Power out rms- 4 o 8 homs?
I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
I founs some articles and For Sale posts:
http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
"Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
Jan 02, 2011 | Sony str-4800sd stereo receiver with...
STR-DG520 receiver will not power up
hello it sounds like it could be a capacitor problem or a leaking transistor
regards
shaun
May 27, 2010 | Sony STR-DG520 Receiver
Ive got a str-dg520 reciever and have a loud hum coming from all speakers have tryed removing all wires then putting back in but still happens
Try replacing the big Electrolytic Capacitors in the power supply section. When they go the let the 50/60HZ hum into the audio from the mains supply.
Mar 02, 2010 | Sony STR-DG520 Receiver
Can I install 4 6 ohms speakers on an 8 ohms a/v receiver? receiver Sony STD HD 800 speaker system: Jamo S413 HC S5 Home theatre system,
Best Answer - Chosen by Voters An ohm is a unit of electrical resistance. You can think of it as your speaker will impede or pull 8 ohms from the amplifier that is powering it.
8 ohms is less resistance than 4ohms. So a 4 ohm speaker would require more juice than your 8 ohm.
If this is the only speaker, then that's all the resistance you have to worry about handling. If you had two of these speakers wired in parallel, then the total impedence would be up to be 4 ohms, because each speaker actually reduces the resistance in the circuit...so 8 ohms + 8 ohms = 4 ohms.
You use this information to make sure your amplifier is powerful enough for the speakers. If the speakers have too much resistance, they'll fry your amp.
Here's a good sentence to help explain, but I recommend reading the article I linked in sources...
"An amplifier designed to put out 100 watts into 8 ohms will put out 200 watts into 4 ohms. Two 8 ohms speakers wired in parallel (4 ohms total) would cause the amplifer to produce 200 watts." Source(s): http://www.marktaw.com/recording/Electro…
Nov 26, 2009 | Sony STR-DH800
Impedance on my Bose 901 Series VI
there 12.9 ohms. there bose speakers not a wallmart if you want a lower impendance then run them in parralell brigde of a bridgeable amplifer/receiver
Nov 09, 2009 | Bose 901 VI Main / Stereo Speaker
I connected my STR-DG520 5.1 to my TV Toshiba
In your str-dg520 menu you have the option to have the sound routed to your tv or out your stereo system. select which one you want.
Jul 12, 2009 | Sony STR-DG520 Receiver
Goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
May 17, 2009 | Sony STR-DG520 Receiver
Sony STR-DB940 Receiver Speaker Impedance Question
Whats the rating on the Plasma? How many watts at 4 ohms? If the plasma is rated 100 w at 8 ohm... hanging a 3.4 ohm load would put a lot of strain on the plasma's output amp. At 3.4 ohm the amp would be trying to delive close to 200 watts at full power. But it depends on how hot you normally run the volumn. Remember an amplifier output is AC volts. 1 ohm of resistance is close to a dead short. The amplifier would have to work its *** off to supply that type of power and would probably burn the output op-amps. If the outputs burn & it pumps any DC current through the speaker wire..the speakers would be toast...if not catch on fire. Try to keep the speaker load at or very cloe to the plasma's output load rating. Also if the plasma doesn't state it will handle loads down to 2 ohms...It probably won't.
Gene
Mar 02, 2009 | Sony STR-DB940 Receiver
47 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
